Build of Bagby Mandolin speaker
Kustomize
Hurray! Yes, this one finally shipped to Amir. He should have in about a week...
Yay!
Am I correct to assume this is the first Jeff Bagby speaker design that will be tested here on ASR? Or has there been others?
Rick Sykora
Rick Sykora
Stow, Ohio USA
Yay!
Yes, they will be the first of Jeff’s speakers to be tested by Amir. :cool:
Rick Sykora
Rick Sykora
Stow, Ohio USA
Truthfully, an original version of Continuums should likely be measured. They are what they are for a reason.
Am familiar with their heritage, but am busy with Directiva and funding it.
May have to hope for a loaner or see if there is enough interest to fund a build.
tktran303
Just to clarify-
Is this using the SB17NRX2 midwoofer?
Rick Sykora
Rick Sykora
Stow, Ohio USA
tktran303
Great. :)
I haven’t used that tweeter either. Apparently it’s been updated with a new metal faceplate.
as you commented bigger woofers and bigger boxes make for a bigger and better sound, at least when 2-way traditional boxed speakers are concerned.
Do you have all those speakers from your build list still, to compare?
I’m really looking forward to the Klippel NFS rotato-gram. ;)
Really appreciating your work.
tktran303
Hi Wolf,
what do you cosndier are the strong points of this design?
I’ve never heard it, but knew that it had certain design targets.
Rick Sykora
Rick Sykora
Stow, Ohio USA
Great. :)
This speaker is with @amirm and is queued up to be tested.
Wolf
Indiana
Hi Wolf,
Honestly, to that point, The Continuums had the lowest HD of any design Jeff had done, top down to about 100Hz. Jeff said so himself on numerous occasions, and to me on premise at his place. The smoothness is almost glossy it's so good, and other than the BBC-inspired midbass voicing, it was flat in response. Bass was not its strong point, but in the vocals and treble they were astonishingly clear. I might even build a pair since I have the drivers on hand. They are a reference that should be appreciated.
forlau
The 3khz dip looks like an edge diffraction problem. The wavelength equal or smaller the distance from the tweeter to the edges gives an additional source, which summarizes or substracts. Its a common problem.
Rick Sykora
Rick Sykora
Stow, Ohio USA
Welcome to ASR!
You may be right on the diffraction but the question is how much? Even without diffraction being factored, modeling suggests that the crossover needs to be lower. The review nearfields suggest this too.
Rick Sykora
Rick Sykora
Stow, Ohio USA
While the design did not call for it, to reduce any speculation (and still had my 7/8" roundover bit in the router), here is the difference between the rounded edge and not...
Red trace is before (not rounded) and green is after (7/8" round). Clearly at this point, diffraction is NOT a significant contributor to the 3k Hz dip as you can see the response barely changed.
Zvu
Serbia
If you make on axis and 30 degrees off axis measurement and the hole at 3kHz doesn't start to fill in (which would surprise me) then you can conclude that you don't have a problem with diffraction and attribute it to poorly engineered crossover or drivers.
What you've tested there enables us to see how much edge diffaction makes of the whole diffraction profile of that baffle with tweeter at that specific position.
Rick Sykora
Rick Sykora
Stow, Ohio USA
You have a point on overall diffraction. This was a quick test just before I move on to other things. Am working on another Directiva build and was planning to repurpose the Mandolin cabinet. I removed the drivers and it is being readied for baffle removal.
Aside from the box tuning (which can be modified to builder’s taste), it is not my intention to redesign any of the DIY kits I have built. While there is clearly a more target rich opportunity to enhance commercial speakers, I would rather spend my efforts on more forward looking designs. :)
Reactions: Zvu
tktran303
Hi Rick,
interestingly I recently discovered a problem with one of Jeff Bagby Revolution Mini 1/4 cu ft speaker; almost by accident.
I was taking in-room measurements of this speaker, to compare it to my Purifi 0.7cu ft (vented Fb:35Hz) design. Really just for kicks.
Apart from the wild swings up and down under 300Hz in my room for the L vs R speaker placement, a very curious thing turned up in the Revolution Mini that didn’t occur in my Pure Millennium 2 way.
One of my Revolution Mini speakers had a hole at 3Khz, similar to this Mandolin.
I didn’t think the room could affect this. After a lot of troubleshooting, I tracked it down to one shorted capacitor(!) in my HP filter for the tweeter.
I was shocked because
a) I’d not heard this 3Khz hole when listening; at least not with both speakers together
b) I’m not sure when the cap was shorted- a faulty cap from new, or during use (~1 year old speaker)
Had I run a full impedance trace of both speakers when I built them I would have detected the mismatch.
Among other things it highlights the dangers of DIY speakers- apart from building things incorrectly (really easy to do; plenty of times in the past I have I’ve done all kinds of boneheaded things) but without basic measurement tools (Dayton Audio Tester System; or similar) I would have have detected this.
I’m sharing this with you since I know Jeff seemed to prefer an acoustic LR4 1.8Khz crossover for many of his 2-way designs, with an 2nd order on his woofer leg and 3rd order on tweeter leg.
Do you have another tweeter to compare to?
Did the Mandolin/2 speaker come with a published impedance trace? I wonder how else you can check whether it’s a tweeter issue or crossover issue? Do you have another tweeter or crossover to compare to?
Rick Sykora
Rick Sykora
Stow, Ohio USA
Hi Rick,
No, no published impedance trace. I did check the Mandolin crossover to make sure it was fully working though. I did try to sim the design in VCAD and it did replicate the dip in a simple model using the SB curves. So, I am fairly confident that the crossover is most of the problem.
Since seems unlikely Jeff messed up, the driver changes must have impacted the design more than expected. As Meniscus continues to market, seems they should own the situation, but Mark has not demonstrated any interest in addressing. :confused:
