Builder's review of Ghent / IcePower 125asx2 module amp
617
Somerville, MA
There seems to be interest in the IcePower boards provided by Bang & Olufsen, many of which are available to consumers now. In the USA, Parts Express will sell you many different models, but if you go on ebay you can find others - in particular is the 125asx2, which is a two channel amplifier with a power supply built in, promising 125 watts per channel. It can also be bridged for I think 500W, although this requires a purpose built input stage. Seems like a great amplifier for home use.
See the datasheet here:
https://www.parts-express.com/pedocs/specs/minidsp-icepower-125asx2-data-sheet.pdf
I reviewed the distortion and output of the different models, and while their isn't much deviation, some had a little less distortion and some had a bit more output. The 125asx2 distortion graphs for 115 operation can be seen below:
As you can see, into an 8ohm load the unit stays below .02% distortion, and for much of the bandwidth of the speaker you're at .005% or less. Distortion starts to go up at 50 watts at 8 ohms, or 80 watts into 4 ohms.
I'm currently designing a speaker with a fairly robust high xmax 8" woofer, and 50 watts into that driver is around the excursion limit in a bass reflex cabinet tuned to 30hz, at which point you're looking at 97db at a distance of 6', which is louder than I personally listen. So, for a pair of bookshelf speakers or moderate 3 ways, this thing may give you what you need. If not, I highly recommend the 500asx models, which are more expensive but offer quite a bit of power. The 500asx and 125asx models seemed to be the sweet spots in the line to me.
Speaking of expense, I built this for a small second system I am making, which is why I wanted to try the icepower module instead of hypex nCore. The 125asx2 module came from ebay, shipped from California, for about 125 dollars. The case and wiring harness came from Ghent audio in China, and cost 90 dollars (I believe shipping was free?). All told, this amplifier cost me under $220.
See this page for pictures of the case:
https://www.ghentaudio.com/kit/asx125-sr.html
If you wanted to make a pair of 500W monoblocks, it would cost you $912. There are also 1000W icePower boards used in Rowland amplifiers, and 200W modules. These modules are available on Parts express. These modules are all mono, but parts express sells a 200W module without power supply that can be powered from another 200W module without a power supply. Ghent sells a case for precisely this configuration.
My impressions of the building experience: the case from Ghent looks good enough, although the case for the ncore units has nicer branding (this has none on the front.) The proportions with the included feet are appealing to me. The input and outputs are of nice enough quality, although the iec plug was very hard to insert. The speaker terminals are quite heavy duty so soldering to them requires patience. The LED is not overly bright. The wiring harnesses are quite nice - the output wires are heavy gauge, and the inputs are nice slinky silicone coated wires.
Importantly - the case comes with no instructions, so you will need to use your deduction skills to figure out what standoffs and screws to use where. To wire the unit up, refer to the icePower datasheet. Here are some tips if you're doing this:
1. This one is important - there is a blue wire jumper which can be placed on two different locations on the board, one location for 115v operation and one for 230v. Mine came in the 230v position, which would have possibly damaged the amplifier if I didn't check it and move it to 115v. The datasheet clearly shows the locations of these terminals but isn't explicit about how to set them so I will be - put the jumper on the voltage that corresponds the voltage in your locale.
2. One of the screws for the feet is silver, not black. This is the grounding screw - use it for the foot which goes near the power input. Ghent has scraped away the paint around this screwhole to make good contact.
2. The standoffs for the switch and amp module are all nylon, except for one which is brass. I assumed, hopefully correctly, that this was supposed to go to a grounding point on the IcePower board. The hole for this standoff also has the paint removed around it, and the corresponding hole on the icepower module has a flat tinned area.
3. The switch is hard to screw in, you'll want a good slender shaft screwdriver
That's it I think. It took me maybe 40 minutes to assemble and 40 to solder the connections. Unlike some electronics projects, the case is pretty big and easy to work in.
The sound? Well it sounds like an amplifier, nothing jumps out at me. So far I've only checked it to see if it worked. It's certainly powerful enough for my use. I'm going to send it to Amir to hopefully get characterized soon. The SINAD chart for amplifiers uses a 1khz tone at 5W into a 4 ohm load - according to our datasheet we can expect .002% distortion, which comes out to a best case SINAD of -94db, but who knows if we'll get there.
Matias
São Paulo, Brazil
Nice. Could you post some pictures of the finished inside?
617
617
Somerville, MA
Juhazi
Finland
I have 125ASSX2 and 50ASX2 boards in my 4-way speakers. They have been powered almost 24/7 for 5 years now, without problems. A friend helped me to install them in cases (125 and 50 in a box per speaker). 125 module drives a sealed 10" woofer and a 12" nude dipole mid, to intolerable spl levels where excursion ends. No need for more power here! 50 amps drive B&G Neo planar dipole drivers. You can see the amp on the floor next to the speaker. They sound simply purrfic!
Ron Texas
Parts list?
raistlin65
Grand Rapids, MI
I love my ICEPOWER250A amp sounds very good for the price in my opinion(better than my sony receiver). I got it for around $200 on Aliexpress for a dual module amp(ebay link).
Looked promising on the item description setting. It is powering a pair of ELAC UniFI UF5 Speakers. Overall I'm glad i took the gamble :p
I followed your lead. Based on all the good recommendations for the IcePower 125asx2 amp module, I've got a pre-built on order from the same Ebay vendor.
Tim6622
L.A. area california
Well just know it's a gamble. Who knows what the measurements might be, although it does sound subjectively good with my Nu audio sound card feeding it. Construction is good. I was planning of perhaps buying another one(or shipping mine) to amir for testing. It'll be entertaining since I want to find an amp at this cost with ~ 96 sinad, but honestly that's having high hopes since QC is not an attribute these giant unkown Chinese merchants have.
raistlin65
Grand Rapids, MI
Well just know it's a gamble. Who knows what the measurements might be, although it does sound subjectively good with my Nu audio sound card feeding it. Construction is good. I was planning of perhaps buying another one(or shipping mine)and shhipping to amir for testing. it's It'll be entertaining since I want to find an amp at this cost with ~ 96 sinad, but honestly that's having high hopes since QC is not an attribute these giant Chinese merchants have.
I did receive it last week. I agree about the construction. Very nicely done.
For what it's worth, the amp sounds significantly better to me than the Parasound Zamp V3 I was using in my desktop setup with PSB Imagine XB, JDS Labs Atom, and Topping D50S. I have tried four receivers and two other digital amps in my desktop setup over the years through various iterations of speakers and other electronics, and this is my favorite so far.
Maybe I should send my Parasound Zamp to Amir for testing since I have no use for it at the moment.
loprent1
Is there a changeable voltage switch/selector on the Aliexpress product? I'm looking for something good that is under $500 to use in 110-220v
Matias
São Paulo, Brazil
The ICEpower 125ASX2 module has a jumper with a blue cable that you can switch positions and it supports 110V or 220V. It is simple to change it, I have done several time. If possible both ways I suggest running it in 220V as it gives a little more power as per the datasheet.
Matias
São Paulo, Brazil
Oops, I fixed the arrow on the second image as it was pointing to the wrong location, but the datasheet image first is very clear.
