Burson Audio Spend a Year Re-inventing the Switching Power Supply
TurbulentCalm
Australia
I think most members will get a kick out of this review of Burson Audio’s super high frequency switching power supply.
Ticks all the boxes: creamy smooth - yet superbly detailed audio, capacitors under vastly less strain, darker sound when no audio is playing, noise floors reaching the Earth’s core. Oh and many veils lifted.
TurbulentCalm
TurbulentCalm
Australia
Oh and I forgot to mention it has a healthy price tag that just proves that it will satisfy the most critical Audiophile.
escksu
Clean power is very important to the performance. However, I am not sure if this power supply does works as mentioned. Would need to test to know. Maybe someone can buy and tear it apart to see the internals?
Count Arthur
The miracle here is dragging a power supply test to 17 minutes!
Koeitje
Zero measurements of the performance, what a great review.
TurbulentCalm
TurbulentCalm
Australia
I wish someone with money to burn would buy one of these and do a tear down. Would be interesting to see how much the internal components actually cost. I expect to see a huge markup on this power supply, even if it is using ultrasonic frequencies.
TurbulentCalm
TurbulentCalm
Australia
Actually what I think Burson Audio is telling their valued customers is that they really crap at including simple power line filtering in their equipment and that the supplied power bricks are not really fit for purpose. But that’s ok just buy these new ones for every piece of Burson equipment you own and it will fix the problem.
After all if you can afford Burson Audio gear you got too much money anyway.
Reminds me of all the high cost headphones, deliberately supplied with janky cables. But no problem, just buy our upgrade cable made from super refined, single crystal, oxygen free copper cables that were dipped in fairy dust and coated with woven unicorn hairs for just twice the cost of the headphones and you’ll be transported to audio Nirvana.
Veri
Actually what I think Burson Audio is telling their valued customers is that they really crap at including simple power line filtering in their equipment and that sort the supplied power bricks are not really fit for purpose but that’s ok just buy these new ones for every price of Burson equipment you own and it will fix the problem.
Funnily enough the one Burson item I've owned had a decent standard power brick and never gave me any noise issues in any set-up. This 'better-er' PSU is just for the audio fools. I guess. In any case, it's a ridiculous price for what seems to be a pretty 'normal' switching supply.
mononoaware
This accelerating playback speed method is effective with 99.9% of videos.
Once you get used to it you can even process 1.75x speed regularly.
iOS YouTube App seems to remember the speed once set (applies to subsequent videos).
Get more content within set amount of time, spread the word.
voodooless
Netherlands
I always find it fascinating when an audio company manages to make a video with the worst sound possible.. Even the most insane flat earthers do much better with their YouTube videos :facepalm:
jae
Combine this with SponsorBlock and uBlock, has literally saved days of time off my life
Save yourself from going in the video menu by using shift + < > hotkeys
mononoaware
Thanks that's a good tip for viewing on the computer.
escksu
I don't expect the components to be expensive. PC mainboard power supplies have a typical switching frequency of around 150-200KHz. I think this power supply could be using the same principle. If so, components are plentiful and very cheap.
Eldus
It would be interesting to have @amirm measure one of Burson's current product stack. With and without their V6 opamps installed.
trl
King of Mods
Iasi, RO
Just found this thread by accident, so below are a few measurements for the 5A and 3A power supplies.
Standard PSU Burson 24V/5A - AC ripple & noise of 8.17 mV RMS @ 10 MHz
Low noise Supercharger Burson 24V/5A - AC ripple & noise of 3.635 mV RMS @ 10 MHz
The above tests were done @10 MHz bandwidth with a stable power consumption of about 74 Watts, the standard idle power consumption of the Soloist 3X GT 2023 headamp (yeah, I know, Class A is really not energy friendly). At let's say 90 kHz bandwidth the results would have been much lower and the differences between the two PSUs would have probably been more evident, like in the below measurements done by WolfX-700 on the 24V/3A Supercharger, the lower power PSU models. Wolf measured these two PSUs while being used in a previous Soloist 3X headamp model which was having a much lower idle power consumption (probably a bit over 10 Watts or so).​
Standard PSU Burson 24V/3A - AC ripple & noise of 1.4 mV RMS @ 90 kHz
Low noise Supercharger Burson 24V/3A - AC ripple & noise of 0.125 mV RMS @ 90 kHz
