boxerfan88
- Joined
- Oct 23, 2018
- Messages
- 407
- Likes
- 452
It's a thread that should be closed and the pixels saved.
Naah. We should let this thread run it’s course. I have my popcorn ready. Subscribed.
Yes, he should only say things the arbiters agree with.Dude needs to read the room.
Bing and Go!!!!So send one to Amir with instructions and some samples of un-burned in cables. Let him test before and after burn in.
it is the gold standard in measurement technique.There is only one reliable test if the burn-in process (for cables or other gear) really works: did the wife from the kitchen stop washing dishes, came over and asked what change in the sound just happened?
The folks on this site will generally be responsive to actual measurements
Well, there are well established measures, like smear to noise ratio or total harmonic haziness, so what is missing?Of course they are. Is that the only thing open for discussion here?
I'm not sure exactly how to test for haze, clarity, openness, transparency, dynamics, smear, etc. It would be great if we could (similar to distortion and noise).
The ears are the most reliable tool of all, that is for sure! Together with the brain, they cannot be fooled!What I have learned is that the human ear / brain is a fantastic measuring device that can pick out things our instruments cannot (so far). When I design equipment I start with pencil & paper, move on to simulations(optional), then prototypes, doing as many measurements as possible. I pretty much tune everything by oscilloscope. Once that is done I use my ears, as it is the quickest and best way to hear if a capacitor brand or type substitution (or any other circuit change) offers any benefit.
The analogy of leather and electric current makes total sense, basically the same things.Shoes break in as well as speakers. A diamond stylus can wear out. It is easy to understand mechanical changes (leather becomes softer with use). Why not electrical? Tubes fade and weaken as emission and transconductance drops.
The main problem is that these things have been tested. and even more important, differences in sound (through FFT measurements such as Amir's) are far below audibility. Further, if you do a level matched blind test, you are so very unlikely to find differences (I mean none at all).Of course they are. Is that the only thing open for discussion here?
I'm not sure exactly how to test for haze, clarity, openness, transparency, dynamics, smear, etc. It would be great if we could (similar to distortion and noise). What I have learned is that the human ear / brain is a fantastic measuring device that can pick out things our instruments cannot (so far). When I design equipment I start with pencil & paper, move on to simulations(optional), then prototypes, doing as many measurements as possible. I pretty much tune everything by oscilloscope. Once that is done I use my ears, as it is the quickest and best way to hear if a capacitor brand or type substitution (or any other circuit change) offers any benefit.
For cables we can check dielectric absorption, permittivity, capacitance, ESL and ESR, field coupling (electric and magnetic). Also, what changes occur over temperature and humidity? Perhaps a TDR would give some interesting results? All of the above parameters could affect sonics. Clearly, a well designed silver / teflon cable might sound better than lamp cord?
