Cable headphones with Active Noise Cancellation
arikarik
Hi,
I need headphones (or headset) that have an ACTIVE noise cancellation, that works when the earphones are plugged to my computer with an AUX cable, and not with a Bluetooth connection to my phone.
Does something like that even exist? Or does the active noise cancellation is possible only with a Bluetooth connection?
P.S: I also need that the headphones would have a mic.
Thank You
RayDunzl
Central Scrutinizer
Riverview FL
raindance
I highly recommend Taotronics. Look on Amazon. We have a few pairs of their corded noise cancelling in-ears and they are a lot higher quality and better performing than the equivalents from Audio Technica.
A
arikarik
thank you for your reply.
do you know for sure though that the noise cancelling feature would work also with cable connection, and not with a Bluetooth connection, and with no application involved?
raindance
Yes! This is the exact model I have: TT-EP008. It is on sale right now, worth a try. It charges using a phone charger, micro USB- B connector.
