Can a Fiio D3(Taishan) drive HD 600s via a JDS Labs Atom?
watchnerd
Seattle Area, USA
He said: Is it being loud enough the only concern? What about "dynamic range"?
Given the context of his asking and that he used quotation marks for "dynamic range" I think he wants to know how capable this amp will be for proper driving his phone, how quick it will be to proper accelerate and attenuate the membrane. He is not asking about loud or not, that is already clear to him, I understand. But I might be wrong, as I said.
Those elements (absence of driver overhang / ringing, lack of resonances, damping factor, etc) aren't really elements of dynamic range.
Nango
D:\EU\GER\Rheinhessen
Exactly. But he used quotation marks for 'dynamic range'. So he wasn't thinking about what you rightfully say is dynamic range.
zermak
Italy
If you mean it as juice to proper drive the headphones in the difficult passages (as per rapidly changes in electric current and peaks) I think @solderdude answered it in his post (I didn't do the math but I trust his words) and he also said there is room for EQing.
watchnerd
Seattle Area, USA
If, by juice, you mean current (the meaning I'm used to), the HD600, with it's high impedance, doesn't need a lot of current. It's more of a voltage oriented load.
solderdude
The Neitherlands
It depends on what you consider dynamic range.
There is something like DR from DR rating and then there is a dynamic range.
This is is the maximum voltage range / smallest signal that does not drown in noise.
There is also a 3rd 'dynamic range' and is the one you are alluding to.
That is the time it takes for a signal to go from max voltage to a very small value.
It is common belief in audio circles that some amps are 'more dynamic' than others and that dynamics are 'removed' somehow.
This can easily be shown when a needle pulse is measured (an actual one, not the one used to test DACs) where the voltage scale is replaced by a dB scale and the time scale is very short.
You don't see those measurements because they are pointless.
They are sort-of included in square-wave tests.
The 'effect' you are alluding to does not seem to be related to electrical properties but rather is a mindset.
Besides, I have tested such actual pulses on many headphones ranging from the slowest to the fastest around and the limiting factor by magnitudes is the headphone driver, not the amp.
So the question you asked about dynamic range can not be anything other than the second one I described = max SPL divided by the smallest signal you can get from it which in this case is determined by output voltage and efficiency as well as noise floor.
The 70-80dB actual dynamic range is another thing that didn't come out of my thumb either. This is the dynamic range the hearing has when listening to music. As the 120dB is magnitudes larger than the 80dB we humans can actually detect in music the dynamic range is enough.
Then there is a 4th dynamic range which is related to the 2nd and is when an amp does not have enough power and starts to 'soft clip' and fractionally higher levels 'hard clip'.
How hard the clipping occurs and how a headphone reacts depends on several factors. In any case when short clips occur the first mentioned dynamic range becomes smaller as peaks only are smaller in amplitude.
At the onset of clipping and short peaks clipping this does not sound the same as hard clipping from a DAC but more like loudness wars compression. It is not perceived as clipping first but rather as 'pinched off sound'.
This too is no problem in this case as the output power is not that of a phone but much much higher.
When clipping occurs your ears will already have dialed down the volume as it would be too loud.
The stopping and accelerating is not a problem as a: the output impedance is low and b: the amp delivers an output voltage not a start/stop/accelerate/brake signal. It supplies a voltage and the load draws a current.
That output voltage (and the current that belongs with it) are tied together. There is no other parameter.
The driver cannot do anything else then follow the voltage. There is no overshoot or undershoot that is determined by anything else than the driver reaction itself to a voltage change.
The amp in question can deliver enough voltage and current to handle 120dB so this 'starting and stopping' myth is a headphone thing and not an amplifier thing. With high output R and drivers that depend on electrical damping there could be an issue here.
In this case too that isn't a problem.. enough voltage, current and low output R.
I hope this explains your confusion about technical dynamic range and the dynamic range you think exists based on subjective findings and internet myths. It is electronics, mechanics and acoustics (and perception). There is no magic involved nor 'unknown' signals.
Nango
I'm waiting really for the first of your answers where you not write the word "magic" at the end of your posting when none of the user before in the thread EVER wrote this word. You insinuate in nearly EVERY of your postings the other people were talking about esoteric, magic, nonsense, etc.
To me it's really hard to read and follow you. You may be the one here with the most knowledge on headphones, electric, electronic, and so on, but letting others know this in every of your answers is just tiring.
Just pls avoid writing the word "magic" at the end of your postings when no one else before has written it.
solderdude
The Neitherlands
That is because there is a connection between subjective found differences, fairies, magic and nonsense but not with technical explanations and causes.
There is more belief in magic, synergy, esoteric and nonsense around in the audio world than there is real knowledge of how things actually work.
Check audiophile websites and it is literally filled with nonsense.
The 'dynamics in amps' myth is just that in most (but not all) cases.
My first reply did not have any magic or insinuations in it (invalidating your argument right there) but a short explanation which you appeared to find unsatisfactory judging on the used emoticon.
I just want it to be clear it is a technical thing, not something that isn't technical.
Julf
Amsterdam, The Netherlands
If the amp and headphone can reproduce a 20 kHz sine wave at reasonable volume, it is capable of "proper accelerate and attenuate the membrane".
Nango
And I doubt it, as otherwise all headphones would sound the same. Also, reproducing sin tones is different from reproducing tons of sin waves at the same time, with different loudness, different dynamics, different everything. Old debate.
solderdude
The Neitherlands
Why would all headphones sound the same if those conditions are met ?
There is absolutely no logic in that assumption.
watchnerd
Seattle Area, USA
I meant, obviously, one given headphone would sound always the same no matter the amp.
If you level match the amps, they're properly engineered, inaudible noise floor, are within a good output impedance / load ratio....yes, the amps will be mostly transparent and the headphones will sound the same from amp to amp.
If you doubt it, try a DBT ABX test with a switch.
Julf
Indeed, old debate. A french mathematician called Joseph Fourier proved you wrong back in 1822.
solderdude
The Neitherlands
Ah... got it, now your remark makes more sense in that context.
Don't agree though that all headphones would sound the same out of any amp...
As @watchnerd explained there is more than just frequency/amplitude in play and level matched blind tests are the only way to find this out.
Max. output voltage swing, output resistance, frequency range, channel separation, distortion character and severity, current capabilities these all can lead to audible differences between amps.
Very possible to do valid (blind) AB tests with headphone amps.
All competently designed amps that adhere to some minimal standards and when not driven near their output limits indeed sound the same under the exact same conditions.
watchnerd
Seattle Area, USA
Yes, AB testing (even DBT with a helper and a blanket/towel), is cheap and easy with headphones. Much easier than speakers.
I've used one of these Hosa passive switches before:
