- Joined
- Jan 27, 2019
- Messages
- 7,404
- Likes
- 12,442
Hey folks, just curious about opinions on this.
Based off other discussions about the pursuit of High Fidelity - in this case interpreted as reproducing the encoded source signal as accurately as possible - we will come to possibly ambiguous areas. E.g. you could have a tower speaker that plays from 20Hz to 20k, but with some deviations from neutral in the frequency response here or there. On the other hand you could have a stand mounted speaker that measures beautifully neutral through it's frequency range, but if it only goes down to, say, 45 or 40 Hz, it isn't capable of producing content that is on a lot of recordings. It's "distortion by omission." So which owner could lay more claim to getting closer to "high fidelity" than the other? The owner of the speaker that can reproduce the full spectrum of sound, though with some deviation, or the owner of the stand mounted speaker that is neutral but which omits plenty of source detail in it's own way?
The obvious answer to the High Fidelity question would be "A full range system (and if you have a stand mount speaker, employ subs) that has been treated/DSP'd to play the full sound spectrum accurately." Hence you have plenty of people owning subs. Though in the last poll there were still 30% of ASR respondents who didn't use subs (and likely among those, people who aren't using truly full range speakers).
Also, in a forum devoted to high fidelity, we see Amirm giving "recommendations" to plenty of stand mounted speakers that omit the lower bass frequencies.
So...I'm looking for your various opinions. For "stand mounted speaker/monitor, think of those limited in bass frequency response, unaccompanied by a subwoofer. One could also include any speaker that doesn't go down to 20Hz, but I'm using stand mount/monitors as an easy example:
Does it make sense to consider a stand mounted speaker a reasonable purchase for someone who has the goal of "High Fidelity?" Even if it measures picture perfect within it's frequency range?
