Hello all,
I am going to check out a pair of these locally and I was wondering if anybody could find a review or any driver information on them. It’s crazy how this speaker is memory holed online. There is this single audio karma thread and that’s about it.
They were apparently the TOTL Cantons in the mid 80s and are rated to 18Hz. They weigh 50Kg a piece and are almost 50 inches tall.
There is scant information online. I’ve attached a picture from the seller.
Technical Data
Technical Data
- Type: 4-Way Bassreflex, Floor standing
- Chassis:
- Woofer: 310 mm
- Midwoofer: 200 mm
- Midrange: 37 mm Alu-Magnesuim-Dome
- Tweeter: 25 mm Alu-Magnesium-Dome
- Loading (RMS-/Peak.): 200 / 350 Watt
- Sensitivity: 95,2 dB
- Frequency range: 18 - 30.000 Hz
- Crossover points: 250/1100/4600 Hz
- Impedance: 4 Ohm
