is that 363 degrees F???Too bad that Carver amp is such a low-power weenie - if it were a true, robust 75WPC tube amp like this VTA-120, you could fire it up and the heat from those big KT120's would help dry out your house.
Larry, FFS relax. Amir's house is flooded.Poll: What happens first:
1. The 275 factory version gets tested.
2. Elon Musk issues the fully autonomous driver software.
Yes, I can confirm there was a heavy equipment operator there moving a lot of wet dirt around.
Poll:Larry, FFS relax. Amir's house is flooded.
Involuntary indoor pools are no fun.Is there water inside Amir's house? Man, I wouldn't wish that on anyone.
All right, all right.Poll:
1. ASR members have no sense of humor.
2. Tesla owners have a sense of humor.
I find the total opposite - amazing how we humans can differ... To me, good solid state doesn't 'sound' at all, but all the valve gear I've owned and used over the years seems to add or change something and often you can't hear recording and production differences so well (I have to say the incredibly 'flavoured' tones of some top ARC preamps still allowed production differences through, just through a rosy tinted window and the E.A.R amps I knew were an artform as the designer could 'design' to spec I remember).My professional experience includes warranty service for Crown, Revox, B&O, Dynaco, Phase Linear, Sansui, Teac, Akai, and many other well-regarded brands. That was in the '70s and '80s. My listening experiences then and since expand that at least three-fold, adding names like Levinson, GAS, NAD, SAE, etc. You can believe that I not only know what solid-state sounds like, but that my permanent switch to vacuum tube amplification some 25 years later was not an arbitrary decision.
As a measurement person, I certainly agree that numerical comparisons between these two genres are worthless. But I also believe the audio industry has produced an overwhelming amount of solid-state equipment for all the wrong reasons. Solid-state gear is cheaper to produce and easier to market to a consumer populace eager to believe it will bring the best of modern sonic technology into their living room. Much of it fails miserably in that regard, but it continues to find favor for reasons of cost, size, power consumption, and above all, profitability. Those of us who believe in the audible superiority of vacuum tube gear are not fooled.
I know this is a contentious subject, and I don't wish to debate it with the masses. Nevertheless, I stand by what I've said here, and I hope each of you who has not enjoyed the privilege of hearing a musical performance reproduced at its finest will someday find the time to audition a well-designed system utilizing only tubes. I do this every day, and like I said earlier, I'll never go back.
Jack
The clipping waveforms of conventional tube amps (e.g., Dynaco, Marantz, Eico...) look the same as any other clipping, and I've seen a LOT of them. The only "soft limiting" I've ever seen is in some single ended preamp circuits. The infamous Hamm paper also only showed this in the same situation.Tube amplifier "soft saturation" has been understood and well-documented in numerous papers and textbooks for decades.
Yah, that's why I put "soft saturation" in quotes. IME, which in no way matches yours for this sort of thing, the transition to clipping is largely a function of feedback and SS and tube designs are essentially the same for most any reasonable design. There may be a difference in a narrow transition region, but if you (not you-you, any you) just think about the waveform when clipped, it does not matter what device is in the circuit -- a clipped waveform is, well, clipped!The clipping waveforms of conventional tube amps (e.g., Dynaco, Marantz, Eico...) look the same as any other clipping, and I've seen a LOT of them. The only "soft limiting" I've ever seen is in some single ended preamp circuits. The infamous Hamm paper also only showed this in the same situation.
One wonders just how much of what is offered is 'market demand' driven, and how much deviation is allowed from a manufacturer's attempt to offer a 'wide range' of product, simply to pad the portfolio and satisfy everyone?I have had good tube systems (ARC, Counterpoint, etc.) ...
But that's because of topology, not because of tubes. You see the same thing with solid state using that topology.I see soft clipping in all of my single-ended power amplifier circuits. Example below - this is a parallel 5687 > interstage transformer > type 45 headphone amplifier. There is some additional power output here as A2 grid drive is happening - 2.1W into a 300ohm dummy load from the 45 with the grid being driven +26V positive. Pushing further, the flattening of the waveform peak worsens but maintains the "soft" rounded edges. I see the same pattern in other circuits when reading a 0V grid.
Exactly. Nothing to do with tubes, everything to do with topology.Many years ago I looked at some guitar amps and found that the "soft clipping" sound was mostly a consequence of single-ended, low-feedback design (more 2HD) and the output transformer (rolling off highs and lows). A low-biased quasi-open-loop JFET before a SS stage did pretty much the same thing.
Getting back (kind of) on topic, that was Bob Carver's point with his t-mod.Exactly. Nothing to do with tubes, everything to do with topology.
