You mean like NO 'local' or 'global' feedback at all?...zero NFB...
Are there many such beasts that do not rely on NFB?
They are probably all tube amps...
I always thought that (such stability w/o FB) was an audio fantasy.
There are a few SS designs. Some I know of:You mean like NO 'local' or 'global' feedback at all?
FWIW negative feedback is a destabilizing design feature. If you want to see a stable circuit condition, apply positive feedback.You mean like NO 'local' or 'global' feedback at all?
Amps without feedback can be quite stable; very resistant to oscillation, since negative feedback and phase margin issues don't play well together.
Class D amps can be built with zero feedback as well.
For any competent designer, stability is absolutely no issue- stability criteria have been well-understood for nearly a century. To quote Klaatu, "I find it works well enough to get me from one planet to another."FWIW negative feedback is a destabilizing design feature. If you want to see a stable circuit condition, apply positive feedback.
You’ve got it backwards mate.FWIW negative feedback is a destabilizing design feature. If you want to see a stable circuit condition, apply positive feedback.
The statement was meant as humor; I was using the Chaos Theory definition of the term
You know what a nuclear detonation is? Positive feedback. As is any explosion - explosives not often described as being stable.
Anything you apply positive feedback to goes to limits.
My room is getting hot - feed back that positively to the heating systme so that it puts out more heat. That is postive feedback.
Ever heard of thermal runaway - that is positive feedback also.
(Emphasis added)Amps without feedback can be quite stable; very resistant to oscillation, since negative feedback and phase margin issues don't play well together.
You know what phase shift does to negative feedback?The statement was meant as humor; I was using the Chaos Theory definition of the term
So, or 'but', depending on how you look at it:
A stable state is one that does not change. An amplifier in oscillation is in a stable state insofar as its output is concerned. FWIW positive feedback is the basis of self oscillating class D amps (like the Purifi) although at audio frequencies that feedback is negative. This BTW is why self-oscillating class D amps cannot be induced to oscillate when subjected to a strange load like one that is heavily capacitive. Its already oscillating... and therefor stable...
Of course there's more to it; apparently you missed this comment, perhaps when you did your facepalm:
(Emphasis added)
The reason negative feedback is destabilizing is due to phase shift. Phase shift is responsible for a design aspect all amplifier designers of amps with feedback must face, which is called 'phase margin'. If you exceed the phase margin of said amplifier, oscillation occurs. So it would appear that the amp is stable if that isn't done... except when the load on the amplifier's outputs messes with the feedback loop, which is a critical design in any amplifier with feedback (a simple resistor is rarely good enough...). Far too many amplifiers have been produced that can oscillate and fail when subjected to a slightly odd load, for example a Quad ESL57.
That is correct.You mean like NO 'local' or 'global' feedback at all?
Did you make that DIY schematic? The hand written text is pretty good. Takes lots of practice to get the text justtt right.That is correct.
A certain, small amount of localized NFB is baked into a vacuum tube (as I understand it, which is barely), but no added local nor global NFB.
Thus the high-ish output impedance (and obviously some limitation of "flat" bandwidth, too).
Yup.Far too many amplifiers have been produced that can oscillate and fail when subjected to a slightly odd load, for example a Quad ESL57.
Negative. (no pun intended)Did you make that DIY schematic? The hand written text is pretty good. Takes lots of practice to get the text justtt right.
That'll never work! There's no ring round the tube electrodes, so all the vacuum will leak out.That is correct.
Thus the high-ish output impedance (and obviously some limitation of "flat" bandwidth, too) of this (and similar) amplifier.
That's you?You'll, at least, recognize the fellow in the center, I reckon.
Yes, that is what I said but not in so many words.You know what phase shift does to negative feedback?
Turns it into positive feedback.
Now that's the words of a dealer !Listen to it? Why do that? Audio Science Review is about sine waves and powering resistors, not music powering loudspeakers.
If its cheap and built to test good, its golden, no need to be musical. Audio reviews without listening. If you don't actually listen to an audio product in a review, your name might be more accurately
@sergeauckland,That'll never work! There's no ring round the tube electrodes, so all the vacuum will leak out.
negative. It's little Herbie ReichertThat's you?
Similes are, too. Well, maybe it's metaphors that are -- but they're, you know, like similes.Smilies are free of charge (and free for use) @ASR.
