CD vs hi-res
David Harper
I know this subject has been debated, ad nauseum, before here but I would like to see a vote on this here. How many here believe they hear a sound quality difference between CD and "hi res"?
muslhead
Define hi res. Without it a vote is useless
Jimbob54
Yup- per that poll, unscientfic as it is, the vast majority of responders say they cant discern a difference between CD and "Hi-res" Which accords with my take on the overall tone of the posts I have read on here the past few years from established members.
A different take but the one I think that really matters to most members , is along the lines of "give me a good recording/ master/ version in pretty much any format over a hi-res "bad" recording.
cany89
It depends on the recording. I especially like to see if there is difference between a CD that I have vs 24/96 or 24/192 of the same published mastering. I got some idea. Most of the time they are the same or the tiny bit of difference is just masked in my listening room - as would in any average room…
Considering the scandal of hdtracks (most of the high-res material is just upsampled…) and maybe the other 1/3 of material doesn’t have any difference other than the filter, there is no way to hear any difference in most of the songs…
But I will give you one album that 24/192 really shines as it’s a recent record. Bruno Mars - 24 Magic. Although it’s highly compressed, the resolution of synths, effects, bass, etc. all are amazing. More noticeable on headphones, less so in my room. I wouldn’t die to listen high-res version but since Qobuz already have it I’m happy that I’m listening it :)
D
David Harper
My experience has been that there are two possibilities;
either there is no difference or
any difference there is so subtle as to render it irrelevant
perhaps with the best electrostatic headphones and the hearing ability of a 10 year old or my dog there might be a small difference. But what difference would that make?
Frgirard
perhaps with the best electrostatic headphones and the hearing ability of an 10 year old or my dog there might be a small difference. But what difference would that make?
24 bit. What the age come do here?
GXAlan
@amirm likes to talk about the roll off performance of a DAC, whether it is sharp or slow. (Denon vs. Marantz). High resolution (and DSD) puts the roll off outside of the area of audibility.
Dr. Aix, who SELLS high resolution audio, has explained that there is actually very little difference.
IN PRACTICE, when you buy or stream CDs versus buy or stream High-Res, the HIGH RES SOUNDS BETTER BECAUSE IT IS A DIFFERENT MIX. It can have more dynamic range and less dynamic range compression to boost the subjective volume. If you took that high res downloaded file and converted it to 16/44.1 it would still sound really good. But you can only get that higher quality mix from the high resolution purchase.
Roland68
Cologne, Germany
One thing is always forgotten in all of these debates.
If the original source material was not in a resolution above CD quality, it doesn't matter what Hi-Res format / resolution you listen to or compare it in, there can be no difference.
This of course also applies to analog source material. You can compare it to analog recordings in photography. Digitize a 35mm negative or a slide with 20 and 50 megapixels, you will not see any difference.
Everett T
If it is a well produced mix, both sound great. When I field record live music I use 24/48 as I've never found that anything higher was noticeable other then taking up more size.
Wes
of course, there are those who believe in the efficacy of "upsampling" ...
I wonder if that is correlated with being an anti-vaxer?
OTOH, there are some AI based fill in the dots products for post-processing in photography coming out - I think Adobe has one. One could certainly do that in audio - and maybe has already been done for tics, pops, etc.
But, in general, the best study on this is the meta-analysis conducted by Reiss. While imperfect, he found only a marginal improvement.
A study using very high res vs. Redbook or even mp3 with young musicians might be illuminating.
I suggest sticking to speakers/room, the best masterings, and finally maybe power amps for better SQ.
Frgirard
The comparison with a screen resolution does not make sense.
Show us 24bit with a dynamic amplitude over 60 dB.
Frgirard
The best mastering? In my world, the ancient world where you find music lovers, the mastering is the picture that the producer want to give to the public.
There can only be one Master..
And producers deliberately degrades the sound quality between different resolutions is a ruffian: Boycott
The remastering is a betrayal.
Frgirard
No one was able to detect the scam on hdtrack with a Beck track 24/96 in reality a mp3 upsampled.
24 bit is 8 bit of nothing except the seller
