CES 2016: Dayton Audio Constant Beam Transducer (CBT) Speakers
Not sure how many of you know Don Keele or CBT technology. I will write more when I have time but this is a method by which the sound beam can be concentrated and made uniform in a truncated arc. Don has been showing this design for a while (which he perfected while at Harman) but it was always a kit. Now it comes finished for just $1,200.
He had augmented it with a sub using a minidsp. The total package was really good! You all wanted to know about bargain products, this is it!
If you have not heard a CBT speaker, you are in a for a treat. You can walk up to the speaker from 8 feet to almost zero and the sound level does not change! Nor does its characteristics! They make really good rear speakers for multi-channel as regardless of where you sit, you get similar sound left to right.
I asked him to play music with good low end and he played a recording of drums done for him with no eq or limiter. It sounded very good!
BTW the Kit version is $600 (?) less but seeing all the work from painting to wiring I would go for the finished good.
RayDunzl
Central Scrutinizer
Riverview FL
watchnerd
Seattle Area, USA
The data sheet makes reference to some new Dayton brand called 'Epique', but if you go the URL you get 'Coming Soon':
http://www.daytonaudio.com/index.php/epique
Any insight on Epique from the room?
Sal1950
The Chicago Crusher
Central Fl
$1200 each or pair? Including the sub?
Not a rap but isn't this just another play on a line source design?
watchnerd
Seattle Area, USA
Looks like it to me. I'm not getting what makes it special / different from other line stages.
Other than the underwater driver...and not sure why that would be a desirable attribute.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
Do you know what is meant by 'shaded' in that graphic?
Electronic signal delay, I think. Maybe wrong.
Intensity differences among drivers - intensity shading
Curved - divergence shading
Yes. Shading means changing the output level as the arc moves back. I think this design is -6 db and -12 db for the upper clusters respectively.
The math is based on Legendre function:
The order determines the beam pattern. Out of that you can compute the shading (level decrease). Here is an example from Don's presentation:
Here is the directivity without shading:
Notice the chewed up response as frequencies go up. Here it is with shading:
There is still change but it is very smooth.
$1,200 for a pair. The sub is also a very cheap DIY. They sell you the box and this large woofer to go with it.
Line drivers claim to do this but they do not. CBTs produce a constant beam that is independent of frequency. See the unshaded responses above as an example of what people call a "line source" versus CBT.
watchnerd
Seattle Area, USA
Thank you for that answer.
beefkabob
$1450 for a finished pair now. Does that make them competitive at all, considering you still need a sub and a a miniDSP, or just an interesting sideshow?
watchnerd
Seattle Area, USA
Total sideshow.
Doesn't fit the lifestyle niche (too big and weird looking) of blue-tooth/wifi ready high end speakers (LS50W, Xeos, etc), nor the consumer smart speaker niche.
Nor does it fit any of the typical audiophile niches for big expensive separates and passive speakers.
