Cessaro Liszt four way horns
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I believe the TADs are decent drivers fairly flat but only over a fairly limited frequency range, hence the multi driver approach.
hvbias
US
TAD 2" compression drivers have a very wide frequency range, it's audiophile round horns that cause them to beam in the upper limits of the horn, so another horn has to be used, which does the same as the previous horn at its upper range so another horn above that needs to be used.
In something like a large constant directivity horn a TAD (4001, 4003) will go all the way to 20 KHz, they just need some EQ like all constant directivity horns do.
Reactions: pos
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
andreasmaaan
Although they’re beryllium, you’d still expect to see some break-up in the top couple of octaves from a diaphragm that size, plus some (maybe) problematic higher order modes from that 2” exit. Would love to see some measurements in a nice constant directivity horn to see to what extent this is true, and whether it might be worth the trade-off for avoiding a crossover in the upper mids / treble.
hvbias
US
This is about the best I had saved, not a very common way to plot CSDs:
Driver that came with the K-402 horn that Klipsh labels as "K-69" which is a relabeled compression driver with aluminum diaphragm
TAD 4002:
I consider myself very sensitive to tweeter/compression driver breakup (including constant directivity waveguides with the compression drivers), as I just can not tolerate it at active listening levels. As much as I tried I could not hear it on the TAD.
If a crossover can be made to have a superb directivity match with a mid/treble horn (and a smaller format compression driver on the treble horn, say a 1" exit) I am all for it. The issue is I have not seen any that can do this and not be some monstrosity that is incredibly tall and requires you to listen to them from very very far away to create a point source image. The audiophile branded horn speakers horribly fail at both things giving you a true sense of awareness that you are listening to horn speakers.
andreasmaaan
TAD 4002:
Thanks, that’s a really impressive CSD :)
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
If you know anyone with a horn ‘bent’, Cessaro Liszt four way semi-active,
Sal1950
The Chicago Crusher
Central Fl
Dude, you need to straighten up a bit,
And maybe some wire management. LOL ;)
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Cessaro Liszt and Revel Salon 2’s unsold, I am beginning to sense that large speakers might not be as desireable as they once were!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
A further 20% reduction for today only now just £52k inc vat, delivery and installation .
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
20% reduction on Cessaro Liszt , grey,damp Saturday continues!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Horn fancier with large room and understanding wife sought.
Ron Texas
For all I know listening to these is better than sex, but they look too weird to have in my house.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Obviously I don’t know what the quality of sex is like at your place but if you send Thomas a tape ...
Sal1950
The Chicago Crusher
Central Fl
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Cessaro ‘Liszt’ four way horns need a largish new home.
Sal1950
The Chicago Crusher
Central Fl
The close-up of the white horn reminds me of something that belongs in a bathroom.
Sorry
