Cheap DAP ($30-40 MP3 players that can use BT) using a good BT DAC (like a BTR5)???
bsas
So, honest question...
If one buy those very cheap "MP3 Player" that can decode FLAC (there is a bunch) and play via BT and use a good BT/DAC like for example the BTR5, is that a viable "two piece" cheap DAP?
What would be the limitations of that setup?
Thanks!
Somafunk
Scotland
Rather than having a somewhat compromised 2-piece setup I’d rather spend a few £ extra and buy a Hiby r3 pro Saber that can do all you want plus streaming for £200, by all accounts its actually pretty decent.
B
bsas
Well, I already have the BTR5, so, it is a difference of $200ish vs $30-40ish?
zeropoint
The Hiby R2 is capable of transmitting over BT using the LDAC codec, for example - whereas IME most cheap PDAPs only transmit using only SBC (or maybe AAC) - and can be found currently for less than half the price of the R3PRO (£99,) possibly in anticipation of the imminent release of the slightly cheaper R2 Gen II, which appears to have mostly the same functionality.
