Cheap USB to SPDIF/Optical Converter
RayDunzl
Central Scrutinizer
Riverview FL
In order to take my laptop, and UMIK-1, and miniDSP to my audio buddy's house, to take measurements, and demonstrate room correction, I needed to convert USB from the laptop to coax or optical in order to get the log sweep into his now ancient DAC1 via coax or optical.
So, looked around a little, decided on this for $24:
new-MUSE-Z5-HIFI-USB-to-S-PDIF-Converter-USB-DAC-PCM2704-Sound-Card-Optical-Coaxial.jpg
It's USB powered, limited to 48kbs but it works for audible measurement purposes, taking the USB audio data and outputting it via coax or optical .
I haven't tried the analog headphone output nor the RCA jacks yet.
Seems to be a single chip solution inside, TI -PCM2704.
Here are the guts of it:
And a real review...
Did I mention it comes with a USB cable?
Heat Output: It's two tenths of a degree (F) warmer than the surface it sits on after 24 hours.
Blumlein 88
I bet you could turn that thing into a giant killer dawg. Slap an Intona, a couple Regens, LPS all the way around, and that baby would sing sweet, sweet music like nobody's business. Top it all off with Mutec 3+ reclocker and you're in business. Slap it altogether in a box and charge 10,000 dollars for it. Tell everyone going more than 48 khz is a mistake, and offer free software to downsample hi-rez into the pure sample rate designed for human ears not prop headed engineers stuck on specs.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
I bought the minidsp
I'll keep that in mind should I need different functionality someday...
I expect to use this a couple of times and then forget where I put it.
Sal1950
The Chicago Crusher
Central Fl
You guys are gonna give the site a bad name messin with all this cheap lo fi gear. :(
Phelonious Ponk
I bought a little box from Trends Audio (well-known for their little T amps) UD-10, back when I first got into computer audio, that takes in usb, puts out optical, coax or AES/EBU. Bus powered or battery powered. Never heard a noise from it, regardless of power source. Did a great job until I went wireless and didn't need it anymore. Cheap, too.
Tim
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Phelonious Ponk
Trends UD-10.1 USB Audio Converter
"Burr Brown PCM2704 IC for USB audio conversion" - same chip
6moons gave it a price of $169, another reviewer $149, monoAndStereo blurbed without a price.
You did a little better at $24. :)
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Here's the analog output:
PC REW Log Sweep -> USB -> RCA out -> 3 foot cable ->preamp -> 25 foot cable -> PC
Looks reasonable to me.
Blumlein 88
You're not supposed to show it like that. You should use a scale from 0 to 100 db. That way it looks really flat. You will never be able to repackage and market it with graphes like that. Even though it is more or less +/- .1 db from 10hz-20khz.
I was wondering what I was looking at until you post that!
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Ok, here you go. Full range so we get all the detail.
Looks even better than any Mark Levinson measurement I've seen.
