Barrelhouse Solly
- Joined
- Aug 13, 2020
- Messages
- 630
- Likes
- 671
For amplified harmonica with a tube amp and the right mic though...a speaker consisting of a 15" full range driver must be the worst speaker imaginable.
I have to disagree, for obvious reasons, I myself have found a 2-way to be the best design and best overall sound balance. But like everything this is only possible when the correct drivers are used and how they are used. I don't agree with many "rules" for designing speakers since there are no "rules".a speaker produces wavelenghts 1000:1 which is why tweeters are tiny and woofers that produce bass are big or with long throw.
a 15" fullrange driver will have insane beaming and insane distortion in the high-end, a laughable polarresponse and a rollercoaster FR. dont get me startet with all the qualifications you need to meet when designing a dipole speaker. even with a passive crossover it will never work, and these dont even have that. a 2-way speaker is always better than 1-way, and 3-4-way can always be better than that again.
there is a reason why virtually all high end speakers are 3-way minimum.
A 2 way always suffers from the bass-mid having to do too much. Unless the HF driver can cover a wide range - such as with the JBL compression job.I have to disagree, for obvious reasons, I myself have found a 2-way to be the best design and best overall sound balance. But like everything this is only possible when the correct drivers are used and how they are used. I don't agree with many "rules" for designing speakers since there are no "rules".
One big thing I've noticed is the stress put on steep crossover points, while it might seem logical, with proper testing I have found some carefully planned overlap between drivers creates a very smooth transition between them.
The more crossover points incorporated brings more complications that need to be addressed, that's why you see more DIY speakers going with 1 or 2 drivers, thus minimizing those phase shifts and transition issues that unless properly tuned by extensive crossover testing and huge amounts of time spent working with each single speaker to ensure multiple drivers are reproducing the same exact sound, 4 ways are typically things of the past (when multiple drivers impressed buyers) or only handled by companies that can afford to do it right.
When you see speakers with multiple drivers per cabinet, that automatically does not mean each driver has its own set range of sound, even drivers that look different or have different sizes can actually be playing the same frequency as other drivers in an overlapped design. Now working with crossover design is needed to end up with what's expected as the end result. People want uncomplicated looks and small size. Say goodbye to 3 and 4-way systems when 2 drivers can cover the spectrum. Good crossover design has become the most important part of speaker design at this moment, either you figure it out or you'll never sell any speakers!
Careful planning and testing costs money and making consistent speakers is a must. You'll only see complex systems that sound beautiful coming from companies that can afford to do it. Many times you'll see multiple drivers on huge speakers and you'll find that they are still only considered a 2-way or sometimes a 2.5-way system.
I just wanted to add my 2 cents, on the chinese speakers.
These are really 2 cents.
I would have never bought a pair of speakers from Aliexpress.
Because you cannot trust any technical infos, unless you know the seller, and or the guy who build the speakers.
Because you are obviously not able to hear them before, unless you are chinese.
Because shipping is risky (customs may be involved if it's a knockoff), expensive, and long.
But I've recently found a pair of B&W "clone". Oatlon M3 on the french "craiglist", 1 hour from home. 450€.
As I've always loved the Nautilus style (which is based on a french speaker design from the 60'), I pulled the trigger.
Got them yesterday.
These are small floor speakers (73cm high, including the base, those are basically big bookshelf speakers), copying the Nautilus design.
I've attached a picture, they are on a small speaker stand.
I haven't measure anything, I have neither the tools nor the skills (nor the will).
But after long hours, I have to say these are probably the best speakers I've ever had (and I've had many).
Musical, balanced (to my ears), capables.
My personal conclusion is : I will have a look at chineses speakers in the future.
Regarding measurements, even if I'll buy any recommended piece of electronic approved by Amir (and I did it a lot), I'm won't follow him on speakers, nor on headphones.
It is electronic, but it's not all electronic.
Of course measurements can show some technical aspects of a driver, its limitations, but in the end, even if it's hard for me to say : I'd rather trust my ears, my tastes, than numbers.
I'm following a guy on youtube, you all may know if you are into IEM headphones, called Crinacles.
For those who don't know Crinacles, he measures Headphones (or at least he used to be known for that), rates them, provides EQ settings to EQ them.
I've bought couple of its recommandations. Never ever liked any.
