Chromecast audio
Crimac95
Is it possible to output digital audio from a Chromecast audio via caox cable using a 3,5 mm to coax adapter?
SMc
There's a "S/PDIF (Toslink) Digital Optical to Digital Coaxial (RCA) Audio Converter" at Monoprice. You'll need a mini-tos adapter for a standard optical cable to get digital out of the CCA as far as I know.
C
Crimac95
Yeah, already know that, was wondering if coax was an option as well
C
Crimac95
M00ndancer
Sweden
Like this?
No, you have to understand that the CCA only do two things. Analogue stereo out and Toslink Optical for the digital signal. Hence the need for a media converter. From Toslink to coax, optical to electric digital signal. Lots of cheap and good converters out there. Where do you live?
C
Crimac95
Nvm, thanks guys but I asked cause also my TV has an optical out that I'll connect to a dac that only has 1 opt in. So I think I'll end up buying an optical switch with a remote control
gvl
SoCal
The simple optical to coax converter linked above will likely be a less expensive and cleaner solution.
