Class D amp and SMSP coil whine?
CleanSound
Northeastern region of USA
I have a pair of SVS SB-3000, they both suffer from very minor coil whine. It bugs me, because I am OCD like that.
My experience with electronics with PWM technologies such as Class D amps and switching power supplies often times suffer from coil whine.
Yet, I also have a DIY Hypex NC500, dead silent.
Anyone else with coil whine on their class D or SMSP?
fpitas
Northern Virginia, USA
Probably a squirt of RTV would fix that. Use the electronic grade.
DVDdoug
Most likely it's a coil in the switching power supply (not the actual amplifier circuitry).
fpitas
I'm a little surprised the frequency is low enough to be audible. But silicone goop fixes all.
jonfitch
Wait you just squirt it directly onto a circuit board? No downsides to that? All the videos I’ve seen of fixing coil whine on video cards and PS5s look a lot more complex from professionals.
fpitas
Our production guys just clean things well and squirt it on. They seem under the impression they are professionals lol.
Trangbar
This is excellent information! I have a SVS 3000 Micro that has been whining since I have bought it (2nd hand) and was thinking to contact SVS as I heard they sometimes replace the amp module to address it. I am going to give the silicone goop a try.
Sokel
Mine is covered with it (look at the little white bloops) :
fpitas
No guarantees, but it's cheap enough and difficult to really hurt anything.
fpitas
fpitas
Another use is gluing ribbon cables securely. In the DCX2496 a familiar problem is the connectors working loose. A tiny blob of goo at each end holds them in place forever, or until you cut it.
Sokel
When we have little toroids or other parts that might be subject to vibration, they get gooped.
It's a 300mm x 100mm board,I mean lots of stuff can get shaken in transport,etc.
I would use more!
fpitas
I would use more!
Well, you have to pay people to put it on, so some restraint is usual.
MCH
Noises from svs subs.... @Trangbar I would appreciate if you report back any success or lack of. Thanks.
CleanSound
CleanSound
Drowned it in silicone. That's on top of the existing white silicone.
If this doesn't do it, then I will just have to live with it.
This is a replacement plate from SVS BTW.
fpitas
Lol! They're going for an award from the silicone manufacturers.
jonfitch
Well let me qualify that by saying "Youtube/Influencer Professionals" then lol
Trangbar
I was not as liberal as @CleanSound , but I did smother the area where I thought the sounds was coming from. My method was to remove the plate, plug it in and turn it on and then listen with a rolled up paper cone. The noise seems to be emanating from the coil that was not covered with the white silicone from SVS. I did then plug it back in to listen with my fancy paper cone, and the noise was there still, but seemed to be a lot quieter. I will give the 388 24 hours to cure, and then reassemble the sub and see what the result is.
