Sokel
- Joined
- Sep 8, 2021
- Messages
- 6,226
- Likes
- 6,352
Name the best or forever stay silentRubycon never was tier one. They wished they were.
That might get you blacklisted at Hop Sing's.name names
Despite of the bent PCB, the module has been working perfectly, so we shall see. My request for reliable operation would ask for at least 10 years of reliable service.
We are aware that the PCB is bent a little bit but we have never have had any issues with bent PCB’s so it will be fine.
Fair enough. But the main problem for me is not the one failure but the bent pcb. Which is not a one off and looks like a design failure. If so, it is a recipe for poor longevity.It wasn't intended that way. I'm sorry if it came across as such.
What I meant was that a thread on one manufacturer or specific items tends to focus on the negatives only, without any perspective to the ratio of the devices that are functioning well.
Insufficient numbers and self selection render that futile.
Oh man. I've replaced more IC caps than any other brand. The TTA series used in many cheap guitar amps are horrid.If I was to say an electrolytic brand I've never seen a failure, when in a normal operating environment, it would be Elna, Panasonic/Matsushita (old), Cornell Dubilier, BHC Aerovox or Illinois Capacitor (acquired by CDE).
UghI have sent my photo of the bent PCB to Hypex tech. support and received, very soon, this answer:
If you can see them partially working, it's probably because you can see the individual LEDs. LED signal displays have used diffusion covers for some years now, so if you can see individual LEDs, the indication is already some years old.Today I see many of these LED traffic signal bulbs only partially working. It seems that they don't generate enough heat to survive the mild winters and storms around here (Charleston, SC USA). 3 or 4 two to 4 day freezes a winter. And many storms in the late summer an fall with heavy rains & gale+ winds. Lot's of manpower hours and equipment hours budget killing of the government tax revenue going on because of these vastly over rated, over promoted bulbs. And many failures of them in my own home, although my power bill is lower due to the fact that the LED bulbs make less heat & the A?C runs less. But the money I saved has been spent replacing dead LED bulbs that sometimes don't last a year before being tossed out. H'mm these things also cause much driving around to try to find a brand that might last. And time lost that you cannot get back.
The OP and several other posts contrasts the reliability of class D amps to class AB amps. The thing is, the type of amp is completely irrelevant when it comes to reliability - it's all down to the design goals of the manufacturer. You can make a very reliable class D amp and a very unreliable class AB amp, or the other way around.
As a point of reference, here's the insides of an industrial, 400 W (total), three channel "class D amplifier" (it's an Omron servo drive):
Servo drives are commodity items - they're mass produced by multiple manufacturers - and since the buyers are mainly large corporations with factories the focus is function, reliability (if one of these fails it's likely to halt a production line which is expensive, and as a result these are much more reliable than most consumer electronics!), cost, and also good, factually correct documentation.
You can actually buy these as an individual; the cost is about 1650€+VAT in single quantities, so in the same ballpark as our audio amplifiers.
What do you get for this money? Look at the heatsinking solution: a custom, beautifully cast aluminium heatsink makes up the main body of the unit, and although it's not visible in the photo I can assure you that there's no PCB under tension involved in securing the beefy switching elements to its milled bottom side! The capacitors are Nippon Chemi-Con, Nichicon and United Chemi-Con. (Ironically, this amp had a capacitor failure, but due to user error - 400 VAC applied instead of 230 VAC - so not due to any design issue.) There's also some pretty advanced DSP inside to control the current through the coils (stator) and the movement of the diaphragm (well, rotor - to millionths of a turn).
This is what's possible to manufacture when the customer is "aware" (focused on functionality, reliability, and cost - and more or less impervious to BS).
Very similar to the devices I designed and project managed over a 35 year career. I worked on drives for AC induction machines - but the principles are very similar, including cost of failure. We designed devices going up to 250kW (Higher in other parts of the organisation)The OP and several other posts contrasts the reliability of class D amps to class AB amps. The thing is, the type of amp is completely irrelevant when it comes to reliability - it's all down to the design goals of the manufacturer. You can make a very reliable class D amp and a very unreliable class AB amp, or the other way around.
These devices are typically three phase full wave uncontrolled rectification onto a DC link (Bulk capacitor), direct from mains supply. Protection against double+ the supply voltage is not really feasible. Also designed to be installed by qualified engineers.Interesting it has no overvoltage protection for the control supply- the bridge rectifier has clearly got very hot, the cap has vented and likely the TNY smps controller is totalled too. Did the venting damage the digital board? I can see elctrolyte 'blast' on the connector shield can.
Wow - that lab looks like real "mad professor" stuff
Like Nicola Tesla, right? But this is an independent and internationally accredited High Voltage Laboratory.Wow - that lab looks like real "mad professor" stuff
