tomasai911
- Joined
- May 26, 2023
- Messages
- 25
- Likes
- 8
What dac is in the minidsp Flex HT?? ESS 9028?? I am assuming it is not the same as the one in the 2-channel minidsp Flex version since it has 8 analog outputs.
The Flex Eight uses an ES9080Q, so chances are the HT does, too.What dac is in the minidsp Flex HT?? ESS 9028??
Flex Eight and Flex HT have identical specs for their DACs (111dB SINAD, 125dB(A) DR).Flex: SNR@120dB(A)
Flex HT: SNR @128dB(A), THD+N @ -111dB (0.0003%)
This is on their web spec pages and seems to indicate another dac similar to ES9028Q for the Flex HT, which they already use for SHD series
Ok then minidsp Flex HT has a typo on their online spec page then regarding SNR if they are exactly the same dacs.Flex Eight and Flex HT have identical specs for their DACs (111dB SINAD, 125dB(A) DR).
We know from teardowns that the Flex Eight uses an ES9080Q.
It is therefore highly likely that the HT, too, uses an ES9080Q.
STOCK UPDATE(19/07/2023): This product is currently in final stages of firmware development to finalize HDMI test. We expect shipments to start in the coming Q3 2023. Thanks for your patience!
Source please?STOCK UPDATE(19/07/2023): This product is currently in final stages of firmware development to finalize HDMI test. We expect shipments to start in the coming Q3 2023. Thanks for your patience!
Sorry, I thought it obvious enoughSource please?
Yeah I looked it up and came back to say never mind. I thought you had some sort of inside information.Sorry, I thought it obvious enough
miniDSP Flex HT
miniDSP Flex HT, 400MHz Sharc DSP audio processor, toolbox for subwoofer or multiway speaker tuning, USB/HDMI ARC/EARC, WISA, Optional Multichannel Dirac Live license for room correction,www.minidsp.com
For me personally, it's going to be the matrix mixer, PEQ, and crossover.I‘m really worried about the price.
For 1100€ you can already get a 11.4 channel Denon X3800 which has all the decoding, 9 channels of amplification, 4 individual sub outs and music streaming build in.
Yes, the flex has a nice small case but what’s really the benefit of the flex HT? (Don’t just tell me it’s higher SINAD)
For advanced PEQ, matrix mixing and speaker correction above Schröder (with given spin data) it’s a good device.For me personally, it's going to be the matrix mixer, PEQ, and crossover.
is it possible to combine 2 unbalanced channels as one balanced output?Yet. I wish they would also release this with balanced TRS.
Hi Peng. Not sure I understand. 2.1 requires 3 channels, this has 8. Would you mind explaining?
i can’t speak for MiniDSP, but I doubt they can add HDMI out. There is not much space on the rear panel for additional connectors. if you need an HDMI out, just add a splitter in front of the flex.
