Comparing HP DAC/AMPS
RHO
Belgium
Hello all, first time post here.
I have a question regarding lower budget HP DAC/AMP reviews:
I was wondering why most reviews compare one DAC/AMP to some other (very good) DAC/AMP. I would think it more helpful comparing a DAC/AMP to for instance a 3.5mm laptop output or 3.5mm output on a phone, since that is the standard situation we want to upgrade from.
Has anyone done this comparison before?
RayDunzl
Central Scrutinizer
Riverview FL
Reactions: RHO
Doodski
We need more samples to test like what you suggest. Motherboards, cel tels, notebooks etc. Testing motherboards req's sending a entire tower to @amirm . For that reason we only have one motherboard tested as far as I remember and that was @amirm Gigabyte Z390.
Reactions: RHO
NTomokawa
Because, I dare say, they're usually not that good. Though I am saying this without data to back it up.
But I'm also saying this because the output of your phone or laptop is most likely not remotely engineered for Hi-Fi requirements (SINAD, linearity, output impedance, etc.)
Then again, whether you can hear any differences is something else entirely.
Reactions: RHO
R
RHO
Belgium
I see. I didn't realize what the process was for getting samples to test.
Thanks for the links. I'll check them out. I'm certain there's quite a bit to learn from them. :)
I would guess the same. I think a product specifically designed for hifi reproduction should sound better or at least show better measurements in that regard.
The thing is that as a first upgrade I would like to see how much better it measures (a basic dedicated product compared to a standard not dedicated product). That could give me a better view on if I would enjoy my "investment". Maybe I decide to save up a little more and go for a mid-range or high range product instead. Or I don't upgrade at all.
R
RHO
Belgium
I went for it and ordered a Topping DX3 pro. (will arrive late December, early Januari :( )
It's my first audio product of this type. I'm very curious if and what differences I will experience compared to my current listening situation. (direct laptop or phone connection)
The DX3 pro also allows me to listen to my wired headphones when I use my phone as a source, My new phone does not have 3,5mm connection but has LDAC and atpX HD capability.
