Crystal Filters
BKr0n
Have been looking around the web at odd filter designs and these showed up (https://en.m.wikipedia.org/wiki/Crystal_filter). They seem to be used in rf filters a bit. What's the efficacy of them for audio? Can they be used in something like an ordinary analog filter?
voodooless
Netherlands
Balsically none. There are basically no crystals working at audible frequencies, nor do we need filters with very high Q’s.
Also, for RF, things like distortion are way less import than in audio. I bet these filters aren’t doing very well distortion wise.
fpitas
Northern Virginia, USA
That's not really a problem for RF since they're so narrowband. But I have no idea what you'd do with one for audio, unless you want just one note, ringing for several seconds afterwards :oops:
B
BKr0n
I was actually thinking more along the lines of anti-aliasing filters for an ADC. I figured the super high Q would be great for that.
fpitas
You mean, somehow include one as a resonator? Even used that way, a high-Q filter corner will ring.
B
BKr0n
Well poo. Guess it's back to the drawing board.
fpitas
The sharper the filter cutoff, the more the step response rings. Mother Nature has it in for us ;)
voodooless
Netherlands
Why? You don’t need super sharp or steep analog filters because of the digital filters in the oversampling bit.
B
BKr0n
Oh great another overbearing mother :p
I wanted to use a SAR for real time signal processing. Figured if I was in the MHz range it wouldn't make a difference. Turns out I was wrong.
B
BKr0n
Still at it I see… rolling your own ADC should be way down on your priority list.
I'm not a fan of calling it quits. If I want it a certain way, I need to put the work in. All there is to it.
voodooless
Netherlands
Are you also building a DIY nuclear reactor if you need to power your house instead of getting solar panels and a battery?
AdamG
Enjoy the Music your way…
Moderator
Reality
A pocket portable nuclear reactor has always been a dream of mine. Unfortunately I keep running into paperwork and approval issues. So many rules and regulations that stifle innovation and creativity. Bubbleheads take this stuff seriously. :D
mhardy6647
Plus that lead-lined pocket would make the shirt a bit of a bother to wear, especially in hot weather, I'd think.
:cool:
EDIT: w -a - i - t... or are you thinkin' of a coat pocket reactor...
enlightenment dawns. :)
B
BKr0n
Dude if I did I'd be making a lot more money than I am now lmao
B
BKr0n
fpitas
If you do get it to work though, you can honestly claim crystal-clear highs.
DVDdoug
:D :D :D :D :D
:D :D :D :D :D
Tell me how you're going to use that in a lowpass filter
Right... It's a "tuned circuit" (or "device") that can work in a bandpass or notch filter but we want a low-pass filter that passes everything in the audio range (or everything below the Nyquist limit) while blocking all higher frequencies.
Anti-aliasing seems to be a "solved problem". I've never heard aliasing, I've only heard-of it. I could probably intentionally create it by writing a "stupid" down-sampling algorithm.
