- Joined
- Oct 25, 2019
- Messages
- 11,145
- Likes
- 14,821
Also, check the filter type at the bottom of each column. Pretty sure some should be either high or low shelves (with Q) rather than peak. Left click on the blue bump icon.I tried to enter oratory manually into Peace. I'm noticing that the gain values keep rounding up or down so they aren't precisely the same. Do you happen to use Peace? Any advice.
Thanks! (Still learning)
Also, disable the columns with no freq value. Right click on the blue bump icon
