Cute new schiit speaker amps
croseiv
The only thing these products have going for them is the word Schiit.
TonyJZX
well i mean there's truth in advertisng i guess
i think these small niche products from western companies are truly taking the piss
i mean people will lambast the chinese manufacturers but at least they arent pulling off weird shit like this and then telling us it doesnt stink
eg.
no one cares about this kind of thing... their existence doesnt matter to us but its the same thing right? with heaps more features and a realistic price
Music1969
what is the output impedance of this little cutey?
Under 1ohm?
Can drive headphone?
Music1969
Both Gjallahorn and Rekkr have <80mΩ output impedance.
Sure.
So for 15 ohm IEMs like TruthEar Nova, at 50mV output
V = 50/1000
R = 15
P = 0.0001666667
Looking at the graph, THD+N will be fine with IEMs?
Hard to tell from graph a value for THD+N
And whether will hear hiss at 50mV
NTK
US East
The Rekkr has an idle noise of about 7 μV (8 Ω) and the Gjallarhorn about 27 μV.
A high performance headphone amp such as the Topping L30 II has an idle noise of 0.8 μV (low/medium gain, 32 Ω), which is 19 dB lower than the Rekkr.
staticV3
For the Gjallahorn, using Schiit's specs, noise comes out to sqrt(10*8)*10^(-117/20)=12.6μVrms (Z-wt) for 8Ω and
sqrt(15*4)*10^(-117/20)=10.9μVrms (Z-wt) for 4Ω.
If we use their APx report, we get:
.9*9.97*10^((-(117.886+121.701)/2)/20)=9.2μVrms (A-wt) for 8Ω Stereo and
.8*9.95*10^((-(117.006+120.562)/2)/20)=9.2μVrms (A-wt) for 4Ω Stereo.
So not sure where 27μV is coming from.
With the Truthear Nova, the Gjallarhorn will output roughly 123+20*log10(0.00000918888)=22dB SPL of A-wt noise (hiss).
The Rekkr will output roughly 123+20*log10(0.00000296218)=12dB SPL of A-wt noise (hiss).
Especially the Gjallarhorn may very well audibly hiss and both are a lot noisier than modern Headphone Amps.
The Topping L30II for example, will output about -8dB SPL of Z-wt noise when used with the Nova.
NTK
US East
I calculated it from the Schiit AP test report. The plot is from its 8 Ω test.
For the poorer channel, at 100 μW, the THD+N is 0.09%. Assuming it was all noise.
Signal voltage = sqrt(100e-6 * 8) = 0.0283 V.
0.09% of 0.0283 V = 25 μV.
So, OK, it is not 27 μV :p
Ron Texas
Somehow the word "cute" when I think about amplifiers. It also seems a bit odd to use a linear power supply if miniaturization is the goal.
staticV3
Bad idea to use graphs like this to calculate SNRs and noise voltages, as they're subject to FFT gain.
NTK
US East
Ummm ... No.
The THD+N numbers are not affected by (or already factored in) the FFT gain. THD+N is the ratio of the RMS voltage of the fundamental to the mean root-sum-square of all the HDs and noise components (= their combined RMS voltage). Therefore, multiplying the RMS voltage of the fundamental and THD+N will get the combined RMS voltage of the noise when THD+N is noise dominated.
From: https://www.analog.com/media/en/training-seminars/tutorials/MT-003.pdf
Gambertuni
One overlooked advantage of these amps, especially valuable in my opinion, is ZERO HISS that I've been unable to experience with anything even close to this price range.
FWIW I bought a Gjallarhorn a month ago and am having problems with hiss. None of the sonic virtues of this device has been apparent to me and the Schiit customer service is not being particularly helpful. I do regret not having chosen the Fosi V3 instead of this...
AaronJ
I rarely listen to the system at more than 9 o'clock on my Heretic (and that on low or mid-gain), which serves as my preamp.
Position of the potentiometer is not indicative of anything, unfortunately. Pots just trim voltage, so turning it all the way clockwise does not mean you will be at 10 watts. You might be at 10 watts at 9 o'clock depending on the gain and source voltage. Not saying you would be, but just pointing out that the position of the volume control does not indicate anything useful.
Joe Smith
Sorry to hear this...the V3 is just a good sounding, high value little package. I continue to feel that Schiit has those mini amps too high in price. I know they disdain Class D amps, but oh well, I'm happy with them and I have plenty of A/B amps to compare to...
TinEaredOne
Sad for people whose audio chains don't work with the Gjallarhorn. Mine is perfect and integrates quite well into all of my existing equipment. I guess YMMV, as others have not had such luck. For me, it has been an incredible value and I plan to keep it for a long time. I hadn't purchased an amp for 20 years prior to buying the Gjallarhorn, and the other amp in my lineup is a Hafler I purchased in the early 1990s, which is still going quite strong.
mhardy6647
I feel the same way about the poor folks whose loudspeakers aren't capable of full range, concert level output driven by a single-ended 2A3 amplifier (ca. 3 watts per channel). I am just sayin'. :)
