Hapo
- Joined
- Jan 11, 2022
- Messages
- 464
- Likes
- 322
Welcome to asr. Amp looks nice on the desk.
...IMHO it's a mess...!!!...looks a pile of Schitt...!!!...
Hmm...been a long time ....For 100 watt peaks. With the right music and inefficient speakers, it can sure happen. ;-)
In UK where I live this is not the price. Also it doesn’t meet the requirement of size when you take into account for amp and external power supply.SMSL DA-6 Amp, Uses the Infineon chip, rated at 70wpc but will give to up to about 15W of very clean output (measured at this very site.) Tiny, currently $49 on Amazon.
You can't even use them as monoblocks with Saga - you need to move up to the Freya S at which point you're in for $1200 plus all the interconnects. For that price you could nearly get a Ragnarok with far better performance in a single box plus a well-specced headphone amp.I think "these are not the amps you're looking for..." I guess the $300 one x 2 could be a decent monoblock setup, with the addition of a Saga preamp...but that's $900, and to get a new single Vidar 2 and a Saga would be $1100... I know which one I'd be more likely to buy...
I would keep fans away from them.I ordered two of these today. You know what happens next....
Yeah. I haven't read the whole thread. Are they for insensitive headphones or something?I had those on a "multimedia PC", what, two decades ago? Maybe two point five decades ago. Maybe more...
When the Schiit hits..I would keep fans away from them.
or, as we used to say in grad school:When the Schiit hits..
I agree, I have the Vidar 2 and the Gjallahorn and the Vidar is a better sounding amp all around. Use the Gjallahorn for what it was designed for, desktop near field and use the Vidar for Hifi general listening. Bottom line, 2 Gjallahorns in mono do not match one Vidar.I think "these are not the amps you're looking for..." I guess the $300 one x 2 could be a decent monoblock setup, with the addition of a Saga preamp...but that's $900, and to get a new single Vidar 2 and a Saga would be $1100... I know which one I'd be more likely to buy...
No. Wrong. Not at full range and not even resembling a musical experience.Thank you for clarifying your perspective.
Exactly, that's why I provided all those parameters throughout all my messages about power calculations. And those calculations clearly demostrate you one can drive average efficiency speakers to reasonable listening levels at average distances with a mere 5W power.
I think that you will find 1 Gjallahorn will be plenty for a 12X12 room if your only wanting 75db. Mine was with 87db speakers in a 12x12 room, but I was feeding it with a Freya+ and the tube mode adds 12db. So you might not need both of them depending on your pre-ampThought I would elaborate on buying 2 Gjallahorns...
small listening room. Is 12x12 with 10 foot ceiling....I listen at low level. 75db max. is plenty loud...so I wanted as clear and balanced audio. Currently in my room are Triangle Borea Bro3 and JBL L52s I switch between a Nobsound 6p1 tube amp, and a FOSI HD-A1....with a balanced SMSL combo of SU-8s DAC and HO200 Preamp.
Fluance RT-85 and FOSI Box X2 phono pre. (looking for a different phono pre)
The challenge is for the Gjallahorn to sound as good as if not better than those other similarly priced amps.
Those two amps have been performing quite well for me each sounding much better than many would want to admit. (I use a APC Line-R to set proper voltage for the 110v requirement, use proper cables and I have no noise in either and both have been on everyday for months, no reliability issues. The Nobsound I rolled better tubes in and after break in they really are nice sounding.)
My tastes are natural, warm, musical with balance. Non-fatiguing listening at low volumes in a near field small room setting. But I want to live with some balanced monoblocks....and see how that compares. I am willing to try things until I figure out the "final" amp config and selection. If Schiit can make an amp like the Gjallahorn sound good for me...then it is highly likely I will buy something higher end in the future for my "next", larger, listening space.
I guess I will find out soon enough.
Oh and I lurk frequently reading opinions and reviews....ya'll are so clever very informative and greatly appreciated.
