- Joined
- May 15, 2019
- Messages
- 882
- Likes
- 3,640
What definition?
I replied to the post prior to mine:
Muslhead wrote: "xilinx is no more a microcontroller company as it is an op amp company even though they have op amps as logic cores"
What definition?
As @mansr and @Killingbeans said above, these will be labelled Custom/Discrete.A special category is needed for a DAC from Mola Mola:
- https://www.mola-mola.nl/dac.php
It uses ADI SHARC audio processors (DSP):
- https://www.analog.com/en/products/...ocessors-dsp/sharc-audio-processors-socs.html
its a programmable gate array. note the word programmable. I referenced an op amp (analog not digital) to address the point of a gate array being digital. It can be anything you can program it to be.Ahh yes, I see. Of course you are right. After all, it's 'Field-Programmable Gate Array' and not 'Field-Programmable Op-amp Array'
And you can't program it to be an opamp.its a programmable gate array. note the word programmable. I referenced an op amp (analog not digital) to address the point of a gate array being digital. It can be anything you can program it to be.
There's ESS 9038Pro implementations that use an ADI SHARC processor for sampling or DSP purposes, Mola Mola is using it for oversampling to the rate needed in its discrete implementation. But to say the SHARC is special to the Mola Mola is false.A special category is needed for a DAC from Mola Mola:
Jeesh
Dont make it anymore than you can/cant understand.
A CMOS inverter with suitable negative feedback can be, and occasionally is, used as an amplifier. I can't see how you'd do that in an FPGA, though, since it doesn't let you connect the necessary resistors.You actually can get op-amp like behaviour from gates. I assume you get abysmal performance compared to the "real" thing(?), but it can be done.
Spent 20 years either at or competitors of many of the companies listed by the op
VIAPopulating the list of chips for the devices tested on ASR has led to a lot of research into semiconductor companies.
I'm mostly making this thread to ask questions and make a few notes, since audio product manufacturers are sometimes unclear about which chip or brand they use.
ADC/DAC Chip Companies
Microcontroller/FPGA Companies
- AKM Semiconductor
- Analog Devices
- Burr-Brown (acquired by Texas Instruments in 2000)
- C-Media Electronics
- Cambridge Silicon Radio (acquired by Qualcomm in 2015)
- Cirrus Logic
- Conexant (acquired by Synaptics in 2017)
- ESS Technology
- IDT
- NXP Semiconductors
- Pacific Microsonics
- Philips Semiconductors (named changed to NXP Semiconductors in 2006)
- Qualcomm
- Realtek
- Signetics (acquired by Philips and name changed to Philips Semiconductors in 1975, whose own name changed to NXP Semiconductors in 2006)
- Texas Instruments
- Wolfson Microelectronics (acquired by Cirrus Logic in 2014)
- Atmel (acquired by Microchip Technology in 2016)
- STMicroelectronics
- Xilinx
thats not my age, its my iqYour profile info has you listed as 19 years old?
