DAC power supply EU/US
MrNice13
Switzerland
Hello,
Maybee a newbie question here but ive moved to Europe from Canada last years and I got a 240/110 volts adapter for the plugs. Now, one of my amp from Canada got a ~5v Power supply with US plug. I then plug this one in my adapter and in the wall. So it's passing from 110 V to 240V. Can this affect the sound or noise? I would like to buy a power supply for my amp with a EU plug but I don't know the size of the end of the cable that plug in the amp. I wonder if a 5V wall brick works but what kind of USB to..... I don't know the end of the plug lol
Thanks
antcollinet
UK/Cheshire
And what is the adapter you are using?
MrNice13
MrNice13
Switzerland
It's 9 V sorry
MrNice13
MrNice13
Switzerland
I don't find any info anymore on these ahah
antcollinet
UK/Cheshire
Smls793ii
So as far as I can see from the picture here:
The PSU will work from 100V up to 240V. So you don't need any voltage converter. Just a simple US to EU plug adapter without any electronics in it will be fine. Like this
If you want to get a PSU with EU plug on it, then I'd suggest contacting SMSL or APOS.
MrNice13
MrNice13
Switzerland
Thanks to you
Berwhale
If you do need to get a new PSU, then it looks like a fairly standard 5.5mm barrel connection...
Actually, the specs for SMSL's P1 linear PSU say that it's compatible and is a 5.5mm External (2.5mm internal) connection:
(I'm not suggesting that you get a linear PSU, it would be a waste of money)
