unpluggged
- Joined
- Jan 5, 2023
- Messages
- 469
- Likes
- 697
With the "wrong" portion of my reply I refer to the statement that analog control maximizes the SNR, and then I explained why this is not true. Because after you attenuate your DAC output, you still have to amplify it, and that's where amplifier's own noise is added, which is usually tens of decibels higher than the unattenuated DAC noise, especially with active speakers.Do you mean this is both theoretically and also practically, repeatedly measurably wrong? Or do you just disagree?
Now there is the issue of level mismatch when your source output level is too high compared to your amp's sensitivity for effective digital volume control, and this is solved by using fixed passive attenuators that don't degrade the signal.
And besides SNR, analog volume control usually introduces much more noticeable artifacts like channel imbalance (even with relay-based controls due to resistor tolerances), distortion, scratching, switching noise and pulses.
With my ADI-2 Pro FS R I usually listen to music at volume levels between −16 to 0 dB (at +4 dBu ref level), so converter's SNR does not fall below 103 dB. And again, I don't really care about it because I can't hear its noise floor, which in any case is overwhelmed by the noise floors of my speakers and my environment.
