DAC Upgrade - What can I expect?
DaveWKC
KCMO
Hello!
So, here's my situation - I have a Bluesound Node 2i that I am running through a Topping E30. I am still in my return period for both. I have tried using Volumio and Moode player on Pi 4's, but I really prefer the overall experience of BluOS. I did try out the Cambridge CXN v2, but hated it. I like Roon, but my wife is pretty anti-subscription (although I know there's the Lifetime deal) - BUT the extra complication here is that i HAVE to be able to cast FROM a Nest Hub device to the audio system with as little trouble and as automatic as possible. These are hard requirements from the wife. The BluOS device handles this with Bluetooth very seamlessly, where the other solutions I tried did not, and Roon does not support Chromecast Built-in (as a receiver) today. Anyway, my current topology is Node 2i Coax out -> Topping E30 -> McIntosh C22 MK V tube pre -> McIntosh MC752 Solid State poweramp. I have been seriously considering picking up a Topping D90 or a Soncoz SGD1. My overall question is would I actually gain anything from this upgrade with my current situation? I am mainly considering this so I can move to balanced output to the preamp, but this really could just be overthinking it. Or, is there a better streaming/DAC situation that would meet the chromecast audio as a sink situation?
Jimbob54
Hello!
So, here's my situation - I have a Bluesound Node 2i that I am running through a Topping E30. I am still in my return period for both. I have tried using Volumio and Moode player on Pi 4's, but I really prefer the overall experience of BluOS. I did try out the Cambridge CXN v2, but hated it. I like Roon, but my wife is pretty anti-subscription (although I know there's the Lifetime deal) - BUT the extra complication here is that i HAVE to be able to cast FROM a Nest Hub device to the audio system with as little trouble and as automatic as possible. These are hard requirements from the wife. The BluOS device handles this with Bluetooth very seamlessly, where the other solutions I tried did not, and Roon does not support Chromecast Built-in (as a receiver) today. Anyway, my current topology is Node 2i -> Topping E20 -> McIntosh C22 MK V tube pre -> McIntosh MC752 Solid State poweramp. I have been seriously considering picking up a Topping D90 or a Soncoz SGD1. My overall question is would I actually gain anything from this upgrade with my current situation? I am mainly considering this so I can move to balanced output to the preamp, but this really could just be overthinking it. Or, is there a better streaming/DAC situation that would meet the chromecast audio as a sink situation?
If you have no ground loop noise going on then its hard to see what changing DAC/ going balanced would bring other than higher levels into the Pre. Stick with what works if you have no issues.
curiouspeter
San Francisco Bay Area
DAC upgrades tend to be underwhelming.
Just get the Roon lifetime deal. $699 is still a great price if you hate subscriptions. The gain from usability alone is greater than any possible DAC upgrade. Just return the Node 2i and keep the E30 to use with Pi/RoPieee. Or return both and get a Roon Ready DAC like the Matrix Mini-i Pro.
Disclosure: I love subscriptions and I am on the monthly plan.
D
DaveWKC
KCMO
Thanks. I’ve definitely considered this, and had tested it already, but it doesn’t meet the above requirement for casting from a nest hub to the endpoint without involving other devices and complicating the process. If Roon ever incorporates that feature, I’d seriously look in that direction. Bluetooth on ropieee could have been an option, but seems it’s a new feature and I’m having issues getting it to work.
curiouspeter
You can also get a Chromecast Audio and plug it into the Optical input of the E30.
D
DaveWKC
KCMO
Totally agreed - but as there’s no auto switching this defeats the “easy” requirements from my wife. Sigh.
D
DaveWKC
KCMO
Maybe the answer is just to ONLY use a chromecast as the endpoint - best of both worlds potentially - I'd just be limited in features for supporting higher-res audio without conversion
Beershaun
Yep. Focus on the convenience factor. That is what is worth spending money on. What does she want to use to choose and play music and works backwards from that. Does she use a smart speaker and voice command today or an app like spotify?
D
DaveWKC
KCMO
She uses simply the Google nest, and expects it to just "work" whenever she wants it to. The only subscription we have is Google Music and Apple Music. Meanwhile I use Vinyl, streaming, FLAC from the network, etc - I don;t mind the extra work - she does. The BluOS device actually works well in this regard, as Bluetooth can be set to an automatic switch - so, if I have it set on the streaming input (line 3 on my McIntosh c22 mk v), even if I am already streaming something it will switch over to bluetooth once the the Nest starts playing. We just set the default "speaker" for the device to the bluetooth connection to the Node. At least with the node I can do MQA and 24/192 - I think I am much more limited with the Chromecast Audio? Also - I am somewhat concerned about the long term viability of this since the Chromecast Audio was depricated.
Beershaun
Then stick with BlueOS devices or other devices that work with the Nest hub as a hard requirement.
