DAP with digital out
L
lanszelot
I bought 32Gb just I was curious is it enough.
I order all what you wrote on the link.
Do I need heatsink, or cooler?
I do not know is it fitt in the case or not. Today the case will come, but the RPi will come only end of the week.
aandres_gm
Germany
The case I bought/recommend comes with a fan. I personally don't use it, since music is such a light task it barely makes the Pi warm.
L
lanszelot
How can I connect the 7 inch display, and the cooler fan?
I have to connect the same place :/
L
lanszelot
Moode Audio recognize the DAC AMP, but the DAC AMP not recognize the device.
Here is the Video
DAC AMP is Topping DX3 Pro
Plugged in USB2 /original cable not otg/
Moode audio - newest
RPi - 4B 8GB
Display - official 7 inch
What am I doing wrong?
L
lanszelot
I found the problem,
I got faulty cable with the DX3 Pro
Only one problem I have now, the Moode Audio cannot see my external HDD.
Volumio can.
L
lanszelot
Hello,
First of all Thanks for help,
Because the 2TB external HDD cannot work with Moode audio, so I bought 1TB external HDD /same brand, same family, only size different/
I copy my music to the 1TB and it working well.
The 2TB have not only music on it, maybe this is what Moode did not like it.
I need a cooler because I would like to try some other OSes on RPi /I never saw RPi, so I would like to try it/
I am thinking PWM fan with heatsink. Y cable is not the best solution if I could do else. But don know how /if it is possible/
aandres_gm
Germany
Hello,
Did you buy the case I suggested?
Jmudrick
LGV60 (1TB drive, 70 hrs play time) to DX3 Pro using USB Audio Player Pro (bit perfect), Android 12. No problem.
