Dayton Audio WBA31 Streamer Review
Rate this streamer
    Votes: 60 43.5%
    Votes: 68 49.3%
    Votes: 7 5.1%
    Votes: 3 2.2%
This is a review and detailed measurements of the Dayton Audio WBA31 Wifi/Bluetooth Streamer. It is on kind loan from a member and costs US $62.98.
As you see, it is a little plastic box as you would expect at this price. Power is provided through a USB adapter:
Both analog and Toslink digital outputs are provided which is nice. And unusually so, there is analog input as well (I did not test this).
Streaming protocols include Airplay which is what I used for my testing over Wifi.
Setup was smoother than many others I have tested using company's app. You connect to its Wifi AP temporarily to configure it and then you can both control the device and play content using their app.
Dayton WBA31 Audio Measurements
I used my Roon player to talk to the WBA31 over its Airplay interface. Airplay is limited to 16 bits so best case SINAD is usually in the 90s. Here, we get much lower value due to high distortion of the DAC (volume is maxed out):
I was also disappointed that the output was just 0.74 volts. Seeing how this is powered by 5 volts, I expect it to product at least 1 if not 2 volts.
I then switched to Toslink output (which is active concurrently with analog out), and got much improved results:
As noted, this is probably as good as Airplay gets. I then used the App on the device to stream, hoping that it would do better than Airplay. Alas, it seemed to truncate 24 bit samples to 16 bits, causing a ton of distortion.
Going back to analog, here is our dynamic range:
Not great but passable for this type of device.
Jitter over Airplay was quite poor when combined with generally bad response of the DAC:
Since my analyzer can't control the device, I don't have any sweeps for you to share. But I think we have a good picture of the device already.
One doesn't have high expectations going into a review like this but always hope for the better. That wasn't meant to be here. Clearly the DAC is a "checklist" item here with performance likely never measured or looked at. I will probably produce OK sound but you are not going to want to invite your neighbors to brag about what a high performance streamer you have!
Overall value is quite high though and inclusion of Toslink should let it produce much better performance if paired with an external DAC.
Personally I can't recommend the Dayton Audio WBA31. Then again for this much money, the fact that it works and brings this level of functionality may be good enough to spend money on.
Tangband
Sweden
Yet another device based on the outdated Linkplay A31 module. Stick with the WiiM devices, with newer and much better performing Linkplay modules.
Yes. I cant believe there are still people on this forum that believes that all digital are the same and theres no real difference. This test and many others from Amirm shows different.
vkvedam
Coventry, UK
WiiM Mini is a better choice, definitely!
Reactions: VQR
Talisman
Milano Italy
The digital signal is always the same, that's not in question. The implementation may or may not be correct, it may provide true bit perfect streaming or not, it may have a competent dac or not.
Digital is not in question, only the tool that manages it
thewas
Correct, also the possibly audibly degradation problem usually lies in the analogue circuitry, not the digital domain.
AudioSceptic
Northampton, UK
What a missed opportunity. You can do so much better with an RPi + HiFi Berry DAC, at least when RPis become available again at sensible prices.
PeteL
"Alas, it seemed to truncate 24 bit samples to 16 bits, causing a ton of distortion."
In which domain do you think these types of problems lies?
thewas
In which domain do you think this problem lies?
That's why I wrote usually, also converting 24 bits to 16 bits does not cause audible problems when done correctly (with dithering), it is done since decades in almost every conversion of the studio files to typical distribution formats like CD.
PeteL
Yep, "when done correctly" is key.
Tangband
Sweden
Which isn't a rocket science and thus no need for "special audiophile engineering".
You are ofcourse right that this is not rocketscience, but despite of that, we continue to see substandard solutions with jitter and bit truncation in several streamers. Not only in cheap ones. This is a big problem in the bad cases. No analog part can save a bad digital part in a streamer.
PeteL
I did not say anything about special audiophile engineering. But what about volume control, what about jitter, what about noise induced drop bits, nothing in audio is rocket science, but still some do better than others. In real life there is rarely such concept as "bit perfect" There is always manipulations, rounding errors and so on.
Tangband
Sweden
This is a good example of a substandard digital part in this streamer.
thewas
Which are usually not audible though but mainly used to spread typical audiophile FUD. ;)
PeteL
Probably as inaudible as 100+ dB SINAD, but still could be the difference about a product that is great and another considered a total fail. Someone with as many messages as you would know by now that ASR is not about what's audible.
thewas
If some people consider as a total fail something that has a lower but still inaudible SINAD than its their personal thing and not every ASR member thinks like that. ;)
JohnBooty
Philadelphia area
Whatever 24-to-16 truncation is happening, it's completely independent of this device.
I assume Amir is talking about Dayton's own streaming app? Unless you're planning on using Dayton's propietary Airplay streaming app, this bit depth truncation issue is probably not relevant to anybody reading this review.
mdsimon2
Detroit, MI
@amirm does this look worse than the Airplay TOSLINK output dashboard measurement for this device? What does a ton of distortion mean? If you have the measurement can you please share it?
Michael
Multicore
Idk what a linkplay module is but I ordered a WiiM Pro after reading your comment and the product blurb. Thanks!
For now I'm playing Amazon Music over BT5/LDAC and I'm not keen on either BT or streaming from the phone.
