Niklasmagnus
Hi, I want to try an DC blocker to check if the hum/buzz goes away from my speakers (most audible at the surrounds that are closest to MLP). The NAD receiver are rated continuously 7x80 watt = 560 watt so need a DC blocker that can pass through the currant.
Will the Audiolab DC blocker work? I like the separate box format.
Spec:
Or should I try the ifi DC blocker, spec:
Thanks
Spec:
Peak Load : | 600VA |
Audio Power Amplifier Compatibility | <2x150W or < |
ZERO DC Block technology | Blocks incoming DC – up to 1,200mV |
Voltage rating | 90 – 240 volts |
Maximum current rating | > 7A |
Max amplifier power | 880W or VA on 220v 440W or VA on 110v |
Continuous current rating |
Thanks
