Decoupling/bypass & signal path capacitors for op-amps (NE5532 in Aiyima A07 vs. TPA3255evm)
007Shortz
Bremen
Hi all,
I wanted to know if op-amp rolling is a thing. So I changed the standard NE5532 with LM4562 in my Aiyima A07. Result: I couldn't notice a difference.
But I noticed an odd op-amp decoupling in the Aiyima. There was only one 0.1uF cap close to the NE5532. So I added 10uF close to the op-amp as practiced in the TPA3255evm . My impression was an improvement in sound. Aware of confirmation biases and doubts I wonder if someone modified the amp the same way and made some measurements (THD+N or SINAD)?
BR52
Germany
The 0.1uF is good practice. More is not really necessary, but if you feel better……
LTig
Europe
I'd say confirmation bias. The 100 nF cap prevents RF instability, and for damping of power supply ripple the 220uF is good enough. Its distance adds some resistance into the power supply connection which would lead to a very small power supply voltage modulation related to the output current of the 5532. That however should be suppressed by the 5532 itsself (PSRR).
DHT 845
Hi all,
Very often I added 10uF (wima poly) to 0.1uF in various places in DACs, amps, op-amps, PS stabilization. In many cases improovement is easily noticeable.
DHT 845
007Shortz
007Shortz
Bremen
It could be, that the 220uF is part of the 12V regulator and there is a small inductor between cap and 5532. Sadly I have no schematics of the Aiyima A07.
007Shortz
007Shortz
Bremen
A 10uF WIMA needs some space
solderdude
The Neitherlands
Then it should be very measurable.
It is best practice to follow the manufacturer datasheet recommendations for decoupling and PCB layout when mentioned.
007Shortz
007Shortz
Bremen
In the data sheet of LM4562 the same. 0.1 + 10uF ceramics as close to the op amp as possible.
solderdude
The Neitherlands
Then it makes sense to use it that way.
Would be very easy to undo the mod and measure performance with and without the extra cap.
Such is the difficulty with observations before and after a modification when there is no reference.
DHT 845
chuckt62
Editor
Tejas
That 10uF/16V MLCC cap has 12VDC on it so needs to derated 50-75% for DC bias.
007Shortz
007Shortz
Bremen
In the datasheet of the NE5532 it's just a 0.1 μF ceramic. Hence an additional 10 μF is not required, except when the designer of the circuit thinks so and adds it.
The TPA3255evm was designed by Texas Instruments. It uses NE5532 in the input stage. The designers thought it would be a good idea to add 10 μF to the 0.1 μF. So why does TI think the additional 10 μF is necessary? Does it improve the performance?
chuckt62
Editor
Tejas
That would depend on the power supply and PCB design. Also, the Aiyima is a consumer product in a cost sensitive market. TI is particularly concerned with the BOM cost of their EVBs.
Cbdb2
Vancouver
The .1u on the power pin is not for instability its to filter RF out of the DC, the PSRR becomes low at these high freqs.
From: https://www.ti.com/lit/an/sloa069/sloa069.pdf
When a capacitor is used for decoupling, it is connected as a shunt element to carry RF energy
from a specific point in a circuit, away from a circuit power pin, and to ground. Ideally, the
impedance of the capacitor to ground should appear as low as possible to the RF energy that
needs to be rejected. It is important to know the frequencies that are causing problems and to
select the right capacitor(s) to eliminate those frequencies
Cbdb2
Vancouver
So you just wilynily add caps?
Also from:https://www.ti.com/lit/an/sloa069/sloa069.pdf
Misconception number 2: Most designers think that when poor decoupling is suspected,
increasing the value of capacitance will produce more attenuation. The exact opposite is true.
When poor decoupling of high frequencies is suspected, decrease the value of capacitance (or
preferably, do the homework and look up the series self-resonance)
