BitPerfect_
- Joined
- Jul 11, 2021
- Messages
- 179
- Likes
- 43
Indeed, the bass is deeper compared with the previous firmware version.
As it should for $3K more...Not even close. The Holo May leaves it in the dust:
Review and Measurements of Holo Audio May --- Probably the best discrete R2R DAC
After I released the measurements of the Holo Audio Spring DAC, something interesting happened. The reason was because I was wrong about the version --- I measured Spring Lv2 instead of what I thought and declared Spring 2 Lv2.When the developer found me and told me this mistake. I was...www.audiosciencereview.com
The bass it sounds almost like the way it was using the first factory firmware imo as far as I remember. I can’t say that it was / it is exaggerated. (There are 3 versions of Firmwares now for Ares II).As in, the bass gets exaggerated?
In the release notes it specifies they tweaked the bass:The bass it sounds almost like the way it was using the first factory firmware imo as far as I remember. I can’t say that it was / it is exaggerated. (There are 3 versions of Firmwares now for Ares II).
I will install it on mine tonight and see if I notice anything.* Reduce sampling rate change/switching noise with certain transport/streamer
* Fine-tune the sound quality in the mid-range and lower octave of the bass, to achieve a balanced, organic, analog-like sound signature that is characteristic of Denafrips
Who's to say? They don't publish the source code so there's no way to know what they actually changed.I still don't get it.
What "quality" could possibly make the bass stand out more? It makes absolutely no sense, other than if they "cheat" and d¤ck around with the frequency response.
I’ll try to put the v1.0 to see how it sounds compared with the last version. I remember when I upgraded to v1.2 the scene was wider.
for sure it’s not placebo
It’s possible to have a DSP inside? Dunno, just asking.
Human brain.How about if you know a melody well enough and you have listen that song many times before? I agree with your statement, don’t get me wrong …
