I usually just set clipping to be just flickering at the max volume I'd ever use (a bit above reference level), which is less than the max on the avr. For the results I was thinking you set it at .775 V but....Not sure what the input sensitivity is set to. I will check when I get home from work. Should it be set to .775 or 1.4?
What i meant by max volume on the AVR means I had the volume turned up as high as it would go. After setting the AVR volume like this I set the Crowns level to where it would just barely clip when listening to music.
I ran Audyssey after this and my main speaker levels came back at -11.
