Denon Heos Distortion Problem
dualimas
Hey, came across a wierd problem, my Denon 4700 distorts any music I play via Heos, the highs made me think my DBR62s had turned into a B&W ;)
Apparently looking at the 4700 thread Im not the only one encountering this problem. Has anyone found a solution yet, seems to be a software issue.
Thanks
raindance
@dualimas - it distorts everything? Streaming music such as Spotify/Amazon as well as music from a USB drive as well as music from a DLNA network source? Hopefully you have the "Restorer" feature turned off? Denon automatically selects this feature for HEOS and it boosts the highs.
D
dualimas
i havent tested everything yet, as far as streaming services it appears to be every one, since i use deezer and others reported the same with amazon and tidal .
raindance
Did you turn "restorer" off?
D
dualimas
no, havent touched that, can i change that in the avr?, somehow the heos app doesnt have any settings
Roach666
2 years later on a brand new X4700H, still the same issue. Turning off "restorer" did the trick. Not sure what this is for as this just destroys the signal.
ecruz1986
I just purchased X6700H and was startled by heavy distortion in the highs, especially when a lot of high pitched high volume notes apper, like background chorals, cymbals, and some specific vowels and sibilant sounds.
I found the problem to be solely this "restorer" function which was set to "Low" by default. It is complete rubbish and MUST be turned off!
