desk tower 3way WIP.. (BlieSMa t25b + ETON 3-212 + Seas l26roy) + Hypex + PE boxes
H
headshake
Awaiting the end result with excitement!
Cheers! It will be a week+.
Do you have idea on what frequency can be attenuate by felt only and what frequency need to use MPP? I am thinking is whether 2000Hz a good number there or we can go lower and leave the higher frequency to felt.
Splitting the baffle can attenuate multiple frequencies, but does it make the effect lower because you have less area per frequency range?
I expect the felt to run out of steam around 1-2khz. I went up to 3khz because I wanted to overlap the tweeter's range. Where each section is tuned should shift down with each layer of felt that I add.
I hope to measure over each area of the baffle and see if there is anything to see. Again, my baffle is tiny so this could all be a waste.
https://www.researchgate.net/figure...lt-and-wool-felt-with-membrane_fig4_316773713
That is one view of wool felt. The MPP paper used a plant-based jute felt.
more:
https://www.scirp.org/pdf/OJA_2017061616554618.pdf
https://www.researchgate.net/public...ials_with_Improved_Sound-Absorbing_Properties
https://www.researchgate.net/public...xtile-Based_Waste_for_the_Automobile_Industry
The felt I am using is listed as between f1 and f5. This is the more dense stuff so it should be good for what I need it to do.
http://www.usfelt.com/sae_felt_specs.html
The pics are ripped from the papers. They mostly show different densities of felt and different ways of making it. WHXXX, WM, and CML are all felt.
H
headshake
I did not want to solder the tweeter out of fear of cooking it. I also have the need to change out the baffles. Crimping it is! The BlieSMa has gold connectors and I wanted to show it some non-corrosive love. I had to buy all of the gold "Female Disconnect" sizes since none of my drivers are the same. (Thanks, manufacturers!)
I had to use a tiny screwdriver to open up the fem. disconnect. You will go mad if you just try the fem. disconnects out of the package on a driver. Dry fit FTW. The wires are soldered to a SpeakON connector.
https://www.parts-express.com/Gold-...2yHENYAIuG5UM0kc5Uv2_vq0bKy9JYqsaAvBHEALw_wcB
H
headshake
Woot! I got my parts today for the final round of my little experiments. I did a dry fit and things look great.
The scientific paper for the perforated metal that I based lots of this off of is kinda old. There are newer papers that cover what is happening inside the chambers I am making. Looks like a larger hole size could let me control the phase.
I hope to be listening and measuring tomorrow.
H
headshake
Some pics/measurements of the new baffle....
"dry_fit_2layerfelt_mpp_noMELAMINEvsMDF.png " Shows what would happen if you had a mic 6" above the new baffle on a table while you played 500-5000hz pink noise from a speaker in the center of the room 2m away. My aim was to measure some off-axis room soup off the surface. Each measurement is made from 10 RTA averages. I would place a 1/2" thick mdf board on top for the mdf measurements. There is no melamine in the new baffle for this measurement, just 2 layers of felt on top and the steel plate. This was my sneak peek before I glued it up. So far so good!
The unexpected thing is I both hear and measure more bass. Steel seems to really start reflecting around 600hz.
I also need to take a higher SPL distortion sweep.
The decay looks great to me. None of my felt-alone measurements look this good.
Back to measuring....
H
headshake
I have some slapdash data to compare a hardboard baffle with no felt VS the new baffle. I did not think of comparing until after measuring for different things. My plan is to do a better job later by using the same drivers for all the measurements. So keep in mind the drivers are my other set and the eq is meant for the new baffle. The spl's were also a bit different for each sweep. A laser measure was used to keep the mic in the same spot.
1m loud = new baffle (2 layers of felt + perforrated steel + airgap (50% air + 50%melamine))
1m wood = hardboard baffle w/o felt
To my newbie eyes, the new baffle is cleaning up 1khz-2khz and a bunch of other nice things. The XO is at 1.7khz. I find it interesting that the XO null moved and there is more power at the XO. I wonder how many of these things can be cleaned up with a better EQ for each baffle? We'll see.
My ears hear a difference. I hope to test my perception a bit when I can do faster speaker swaps.
H
headshake
Some new images from the last week of tinkering.
MPP... the new perf baffle design. In the first round, I guessed at what freqs. to target. Now I have measurements and made chambers to target real resonances. The resonances show up on both baffles, wood, or whatever. I believe the baffle shape causes some frequencies to ring on the corners. I also think some of these issues are tiny speaker problems.
on_axis_1ft... This is an on-axis look at each of the steel plates with a baffle that is 2ft wide (next pic). The all 1khz plate VS the 600ish-3khz plate battle using the same drivers, amps, etc... everything was the same except the plates. I did have to take apart the speaker between measurements. I love how 2.5khz decay gets hammered down by the multi freq plate.
1khz pink... This is the foam sheet around the baffle.
between_ 1ft.. This is a comparison of the 2' wide baffle vs the normal one with the 44mm edge radius. The mic was between the speakers so this is an off-axis look using the same speaker for both measurements. Notice how the decay shifts up with a baffle size change.
baffle sim... I've was going mad guessing at what was happening with the new baffle. I went back to 2D to help see what was going on since my brain stinks at simulating how acoustics work. The sim shows a power increase on-axis and the improved decay- things I see with my real measurements. It also shows that a plain baffle messes with the decay no matter what kind of rounding you use.
https://www.falstad.com/ripple/Ripple.html
Code:
$ 3 1023 127 35 0 1199 0.048828125
202 0 390 553 548 648 0
203 0 421 532 471 532 1 2 8
b 0 470 532 545 582 0
c 0 417 532 471 553 0 10000
e 0 415 563 457 605 0
b 0 397 532 425 571 0
b 0 214 0 467 1018 0
b 0 467 0 719 1018 0
P 1 399 287
P 1 536 287
s 2 463 529 2 2.566663 0 38.274470661478325 147.2095025441474 1 0
s 2 471 529 2 2.566663 0 38.274470661478325 147.2095025441474 1 0
e 0 358 532 431 605 0
P 1 508 486
P 1 427 485
H
headshake
After way too long, I now have the seas l26roy in the final spot. Piano sounds so nice with the bass so close to the mid. Before the l26roy was about 11" away and pointed up. The change from a speaker stand to the wide sub box also changed the performance of the mid and tweeter. I had to bring both of them down in SPL's.
I compared different amounts of stuffing inside the sub-box. If I put in too much, it messed with the off-axis bass- I was seeing a dip at 150hz. I ended up with 2" of melamine spaced 2" from the back wall of the cabinet.
I am also doing a second round of perforated plates for the baffle. This time with specific targets and a nomogram that is calibrated for the spacing+melamine based on measurements of the round 1 baffle. The distribution should be better for round 2. I included an image from round 1 with labels.
H
headshake
My newbie journey continues...
I'm been doing lots of rounds of measurements and eq fixes. I am using FDW in REW to smooth things out. My main interest is finding the spots that need a filter and making sure it does not mess with the off-axis.
For all of the eq rounds, I moved the mic, not the speaker. For rounds 2-4, I used a laser measure and tape on the tweeter to get the distance right. Between all of the rounds, I added/changed filters.
First, the very rough sim made from traced measurements and run through vcad's baffle sim. I also use the baffle sim to generate the way off-axis data. I am shooting for this shape. The only filters I am using from my sim are for the XO. What is cool is that the sim predicts a dip off-axis for the XO and reality shows the same (xo at 1700hz).
Round 1: According to kimmo, a 0.5x wl xo has a bump after the XO. I think this is what I am seeing in these measurements at 2.4khz. Around 6-8khz is also a bit much. The mic was moved at random distances (this is why the off-axis is louder than the on-axis) and I am spitballing the angles.
Mixp_1ft_0degree_tweeter_3ms_20_width_in_cycles.jpgMixp_1ft_0degree_tweeter_3ms_no_window.jpgMixp_1ft_0degree_tweeter_3ms_6_width_in_cycles.jpg
Round2: For this round, I placed the mic 0.6meters from the tweeter. It looks like I got rid of the 2.4khz issue. I would say this covers 0-70 degrees with a big jump at the end because I was getting bored. I forgot to turn off filters for rounding off 10khz and above- this is why it rounds off for these measurements.
psy + no FDW w/ average MIXP_0_600meter_roughPOLAR_psyAVG.jpgpsy + no FDWMIXP_0_600meter_roughPOLAR_psy.jpg1/24th + no FDWMIXP_0_600meter_roughPOLAR.jpg1/24 + FDWMIXP_0_600meter_roughPOLAR_FDW.jpg
Round3: I measured 1 meter from the tweeter. This shows 0,45, and 90 degrees---ish! The mic stand was actually up against the right speaker to take a measurement of the left one. The tweeter is still too hot and I think I see a baffle step issue.
Round4: On-axis only. I started messing with the mid and woofer. I don't have any filters on the l26roy to boost bass.
1/24thmixp_eq6_24th.jpgFDWmixp_eq6_fdw.jpgdecaymixp_eq6_decay.jpg
I will do a few more rounds, but things are looking and sounding nice!
H
headshake
The new speakers are meant for the desk but I thought it would be good to compare them in another room to my JBL 580's.
The topping 10s outputs to spdif and analog at the same time so I was able to hook it to my receiver and fa123's. This allowed for instant swaps between speakers. For movies, I had the toppings 10s connected my nvidia shield via usb.
I also had hifijim from diyaudio over for a listen a few weeks back. I have never met anyone that listens to music like hifijim. He has an amazing ear that reminds me of: https://www.wnycstudios.org/podcasts/radiolab/segments/301427-head-full-symphonies
We listened to some tracks that I thought showed off the plusses of the system and some tracks that I have seen folks use to test speakers.
https://open.spotify.com/playlist/2x8t73JDQPNKW4yTLbPaO7?si=154d8f0340904cde
hifijim noticed my tweeter level was down. I smiled because I did this on purpose for my own ears and it was only a little down. He is damn impressive!
So between comparing the new speakers to the 580's and getting another person's opinion, I have more confidence in the sound. Now I just need to glue everything up and paint.
H
headshake
Now that I am getting close to being done w/ speaker 1, speakers 2-3 are in the works. One is a coaxial and the other a small full-range. I am thinking of a SEAS for the coaxial and the scanspeak 10f for the small full range. Jury is still out through. They will just sit on the L26ROY for bass.
The first graph is a comparison of data from SEAS and audioxcite for a tweeter on a coaxial. I am running both through the baffle sim in VCAD. It looks like I can trust 1-2khz of my sim which is fine for my XO.
I like to ask VCAD questions like "is it worth it to add an edge radius to a coaxial?". Solid is 0 degrees, dotted is 30,60,and 90 degrees. The baffle sim says: "yes if I don't want to fuck up 1-3 khz, a 44mm edge radius will make things lovely." This data is just a sim based on the baffle size and SD of the driver. No trace data.
So I tested out a quick sim from the trace data using the baffle sim. I want a coax that falls off differently than my bliesma/eton 3way and this looks like it. Some more hacky sims should tell me which way to go.
H
headshake
hifijim from diyaudio came over for a listen and to help confirm some measurements with his setup.
This is an omni mic distortion measurement of the 3way at about 0.6m. Looks good to me! I do expect some distortion around the tweeter's XO due to how low I am crossing if things were a bit higher. This is about as loud as I listen so I am good.
Thanks again, hifijim!!!
bigjacko
Is this distortion graph correct? All distortions are cramped at the bottom. Or maybe the scale is too wide to see the small difference between distortions.
H
headshake
The scale is not the norm for sure.
When he did the measurement, hifijim mentioned that he did not like how omni-mic generates reports. So this is a pic of the screen from the app. The key takeaway for me is the distortion is over -40db down at 80db.
I will take a REW measurement so you can see the distortion better and try to play it louder to get more above the noise floor.
My little speaker is changing! Well, not much. I am just moving it out a bit so that the mid has nothing to bounce off of at sensitive frequencies. The L26ROY has a big rubber surround and 1/4 WL spacing is not a good mix. After the change, I could hear greater clarity and sense of space with the mid. Listening to the small SB A coax speaker helped me track this down. The coax sounded bigger floor to ceiling until I made the change. The nail in the coffin was hifijim hearing issues as well. After he visited. I made the change the next day. It will be neat to see what changed in the measurements.
Now I need to cut some edges to make it look pretty.
dualazmak
Hello @headshake,
This is really exciting and interesting project! Your objective approach towards the "ideal SPL for your ears" from zero basis (I mean without reference sound system) is very much impressive for me, since in my similar multichannel multi-amplifier project, I always have/preserve a "reference sound system" driven by single amplifier plus LC-network with Yamaha NS-1000 + subwoofer Yamaha YST NS-1000 + super-tweeter Fostex T925A.
Although your wonderful approach is quite different from mine, I really surprised and impressed looking at your latest whole SPL curve (at 0.6 m) is quite similar to my SPL measured at my listening position.
Just for your reference, I use a HiFi (budget) integrated amplifier directly driving super-tweeters so that the SPL over 7 kHz can be easily flexibly adjusted for age-dependent hearing decline in high Fq over ca. 6 kHz; very convenient and nice for listening sessions inviting friends. I usually use rather quiet violin solo music for their preferred SPL over 6 kHz at the beginning of our listening session.
In any way, much congratulations for your exciting project, and I am looking forward to seeing your further steady progress. I hope we may share and exchange invaluable know-how and information in our two project threads.
all the best
dualazmak
H
headshake
Hello @headshake,
all the best
dualazmak
Hello, dualazmak! Thanks for popping by my newbie project. Your system looks so amazing and flexible. It inspired me for sure!
re:"your latest whole SPL curve (at 0.6 m) is quite similar": That is super cool to read! That yamaha dome is amazing though. If you ever want to trade :p
A little update.
Nobody else will ever see this so I thought I'd post a bunch of pics of dots.
Round 2 of the perforated plate baffle is back on now that have measured the speaker in (what I hope) is the final shape. My plan is to make 3 of these plates to test out. The plates try to zap 1-3 frequencies in a few ways.
MPP_2200_2600_3000hz.pngMPP_half_1200_2700hz.pngMPP_hearing_2,6.pngMPP_hearing_2,8_and_4khz.pngMPP_hearing_2khz_to_4khz.png
Also, inspired by the yamaha dome, I am thinking about the next speaker based on what I learned from this project. It is the same thing but with a dome mid. I will also change the baffle shape a little since it wont need a box.
This is what I am thinking of so far:
The baffle sim seems to like the driver playing 1-2khz right in the middle The tweeter would be crossed at 3656hz. The shape does not show the 44mm edge that I would add just like the speaker in this thread.
Top: the dome mid sim
Bottom: bliemsa/eton sim
