Inpsired by the 9% variance from best-to-worst in CD Rip accuracy between different CD ROM drives shown here. https://forum.dbpoweramp.com/showthread.php?43786-CD-Drive-Accuracy-2019
Use case #1
Compare transports to transports with accuracy % metric.
Use digital output (SPDIF/Toslink) from multiple optical disk transport devices such as CD Transports, DVD Players, or CD Players.
The % accuracy number from each device to be captured in a table. Observe if there is a variance between devices.
CD Transport test method
1. Using a reference music CD on a computer, create a ripped .wav and verify it is a known good copy (using something like AccurateRip.)
2. Use the same reference music CD in one test device. Capture digital output to .wav.
3. Use @pkane 's software DeltaWave to compare the reference .wav to the .wav created by the device, specifically the CLI comparison with % matched output: https://www.audiosciencereview.com/...ve-null-comparison-software.6633/post-1117064
4. Repeat test for multiple devices and store data in a table.
End use case #1
Use case #2
Unrelated to the above, compare CD Players to CD Players with accuracy % metric.
Use analog output from multiple CD Players, captured to .wav and compared to reference .wav.
The % accuracy number from each device to be captured in a table. Observe if there is a variance between devices. It is widely accepted that due to variances in DAC and analog output implementation that the results will vary.
CD Player test method
2. Use the same reference music CD in one test device. CD Player DAC output to ADC interface to capture .wav
End use case #2
This should ignore audibility for now and focus on "Device A created a more accurate replication than Device B."
Use case #1
End use case #1
Use case #2
End use case #2
