Dirac + DLBC with LR active bass section.
geek101
California, USA
I got the multichannel with Bass Control.
All in all I have a 3.1 channel system with my LR speakers having active bass section.
Signal chain HTPC (Dirac + Win11) -> topping dm7(usb) -> amps
How do I split the L to L + LSub etc ? Like an external crossover in Dirac ?.
I am starting with selecting an LCR configuration and adding 3 subs but I feel like converting all subs to mono incorrect technically.
geek101
geek101
California, USA
theREALdotnet
I believe that when you use DLBC, Dirac is the crossover (between the bass and the rest). You need to find a way of getting to the bass amp of the speaker directly. Does it have a separate input?
dziemian
In DLBC you control each channel including bass ones separately. Dirac sets xovers itself based on measurements. In 3.3 setup (LCR +3 subs) you need an interface with 6 channels.
