Dirac Live standalone for PC and Mac
voodooless
Netherlands
Thanks...but the thing is, if I turn off Dirac, the EX5 still shows a 48kHz sampling rate for a 96KHz recording. Shouldn't it display the true rate if DL is bypassed?
I think it processes at 48 kHz, regardless of Dirac is enabled or not.
voodooless
Netherlands
What else could it be processing? I have no xovers, filters, etc, programmed. I thought it would be straight through.
It always goes though the DSP, regardless of any active processing.
David_M
I think maybe when you activate DL license in the software everything goes to 48khz and then it works like @voodooless said
If that's the case, then that really sucks!
I find it hard to believe a full-blown Analog Devices 400MHz SharcDSP can't process digital filters (which is what DL is eventually) 96KHz and beyond for a 2-channel system.
Bullocks!
mike70
Bullocks!
It wouldn't do any difference to sound quality ... acoustic corrections are much, much more important.
voodooless
Netherlands
Bullocks!
It can without the Dirac license installed. The point is, Dirac needs a certain FIR resolution, and this particular DSP chip can only manage that at 48 kHz. 96 kHz would double the needed filter taps. And since only disabling Dirac won’t release the DSP resources for it, you’ll stay at 48 kHz. Uninstall Dirac to get to the 96 kHz filter software.
Honestly, I wouldn’t worry about it. You won’t be able te hear the difference anyway.
Blew
Sydney, Australia
Doesn't that depend on the reconstruction filter in the DAC?
voodooless
Netherlands
A little. But we know how the filter behaves based on the flex review and it should be absolutely fine. We also know the performance of the sample rate converters in the SHARC DSP: 133 SINAD, 142 dB SNR, 125 dB stopband attenuation . That is absolutely transparent.
Anyway, all of this it totally off-top, because this is about the PC and MAC versions.
Flak
Flak
Industry Insider
Hello,
the latest beta Dirac Live 3.7..1 has just been published:
with comments about the features, fixes, and known remaining problems.
Needles to say, if you'll find the time and inclination we'll appreciate your findings and comments by emailing [email protected].
Thanks a lot for your cooperation!!
Joaquinín
I hope somebody can solve one doubt Dirac DLBC, the PC version. When you have a multichannel setup (2.1, 4.1, etc.), do you need one SW for the LFE channel + another SW for the BM? In the "Channels configuration", it seems that Bass Management ("Subwoofer") and LFE can't be directed to the same "Output"...
kolestonin
just to be on the safe side before pulling the trigger:
I have two speakers with two subwoofers.
I don't have any Dirac compatible gear and I plan to try the software standalone version.
Do I need the stereo($349 ) or the multichannel($499) license for a 2.2 setup?
staticV3
Dirac Live RCS does not support multiple subwoofers, regardless of what license you choose:
You can still run two subs of course, but they would both play the same mono signal, so MSO-like sub optimization is not possible.
Edit: on the other hand, this Manual suggests that Dirac Bass Control™ can be used as well: https://confluence.dirac.services/display/DLS/Dirac+Live+User+Manual
peng
Stereo+DLBC licenses will work.
theyellowspecial
PC? Single seat setup? You can also start by doing your crossovers in EAPO and go with just the stereo license.
janbth
Norway
The file server at Dirac seems to be down (with changelogs and user guides). I have been trying to connect for several days now. Is it just me? @Flak do you know anything about this?
Davide
Milan, Italy
Studio Stereo or Studio Stereo + Bass Control if you have a DAC or interface with 4 outputs.
Flak
Flak
Industry Insider
A heads-up :)
