Directiva r2 project: market requirements gathering
TimVG
Isnt the GRIMM style option maybe the one that makes most sence ?
If you think about it :
1. A wide baffle down to about schroeder frequencies is a good thing.
2. Instead of the Seas exel unit used in GRIMM, why not use two SB 17cac in 2,5 way figuration ? The distortion is lower than purifi.
One SB 17cac plays from 100 Hz ( crossed active ) up to the tweeter crossover at 2 kHz ( crossed active ) and the other from the baffle step frequency, ie from 300 Hz down to 100 Hz . A simple 6 dB aircoil passive at 300 Hz for this unit. No need for baffle step correction then. :)
3.The tweeter could be seas DXT crossed at about 2 kHz.
4.The bass could be GRIMM style closed box with LT with SEAS r0y crossed at 100 Hz active and the digital 3-way crossover a dbx driverack pa2.
whatˋs your opinion about that ?View attachment 162179
It's a good idea which I proposed as well, but Rick is set on a narrow baffle design :) So not an option.
TimVG
Tangband
Sweden
voodooless
Netherlands
Yup, the Monacor waveguide performs quite well and is something worth considering. I was aware of the soundimports link, but we're not at that point in the design phase yet :)
The point was that routing should be easy and custom modification should not be needed. The links shows both do not need to be an issue with a generic waveguide.
Tangband
Sweden
My own DIY active HYBRID had a monacor waveguide. 8A6A8B2C-C3F7-43E1-8864-C97A144F0187.jpeg
Its a custom adaptor for the waveguide. Measurements where very good, but the sound slightly worse, not as detailed than Genelec 8340 wich I bought after doing measurements on that speaker.
Tangband
Sweden
My own experience is that a really good waveguide shouldnt be symmetrical, as the monacors are.
I would look at how Genelec does it and also Revel.1E6764FB-24E2-4179-8493-D19FD51DE37B.pngD14233BE-1A66-47B6-841A-3682941F11E9.jpeg
Reactions: BDE
TimVG
Absolutely true. One more aspect is availability. Since the members are literally all over the globe, it's important that parts are easily obtainable. I'm not sure how readily available the Monacor brand is in the USA for example, it's all stuff we need to consider.
Rick Sykora
Rick Sykora
Stow, Ohio USA
Is a dome tweeter a requirement? Otherwise that would open additional options.
As for a generic waveguide: turns out they fit quite af few tweeters without modifications. Check out this article: https://www.soundimports.eu/en/blogs/blog/wave-guiding-your-favorite-tweeter/
No, tweeter does not have to be a dome. I may use the BG Neo as I have a bunch around here.
While there should be a primary offering, do not want to get too wrapped up in just one answer. A waveguide is not off the table either, but the design team needs to demonstrate why it will be needed AND it better be as simple to do as most other drivers. This is comparable to why truncated frame drivers are not acceptable. Do not want cutouts or mounting requirements that are complex.
Expect the design teams to formally start over this weekend. If you are not on a team, then expect the team leads or I will report progress over time.
Thanks!
Rick
gy-k
One of the R2 requirements is that the system should be relatively easy to build - that will include routing. This means elliptical waveguides and the likes will be hard if not impossible to implement in a flush mounted configuration.
Another requirement is that the parts need to be readily available and usable without further modifications. I know a lot of waveguides require further adapter plates and the likes to be used with otherwise readily available tweeters.
Also I believe 6,5" for the woofer is not set in stone, since this will be a 3-way system - it's a possibility, but not a certainty.
Not sure I'd set high hopes on the availability of a waveguide part either. By the way, just putting a dome inside a waveguide isn't necessarily a great match. The oblate spheroid waveguide assumes a flat wavefront of a compression driver. (I'm just an amateur, but I beleive this much I can repeat.) Mabat's waveguide is one, it's freestanding and needs no baffle/cabinet woodworking effort, it needs to be (ordered as) 3D printed but the plans will always be available.
voodooless
Netherlands
Hey, I still have several of those as well ;)
I would not totally rule them out, you can mount them on the rear of the baffle and do with a circular whole.
sarumbear
Nwickliff
My 2c, which is probably more like .001c, Or more of a question is why are people so obsessed with getting bookshelves (or any speaker, for that matter) to play the lower notes and octaves that generally don't disperse evenly from the main position in "normal" rooms. If properly time-aligned and crossed to a sub and preferably multiple subs, won't you get much more even bass in "most" rooms? It frees up the box design for much more headroom and I would guess fewer issues with resonances too, no? Isn't it better to have each driver do less work in order to get maximum performance? I understand it as an exercise and perhaps that's the main purpose here. Anyhow, happy building.
voodooless
Netherlands
I guess there are many reasons: some people don’t want subs or don’t have room for many. Two additional speakers that have the bandwidth can already act as two subs. Some don’t like the bookshelf design, others don’t like speaker stands.
Lbstyling
I would look at how Genelec does it and also Revel.View attachment 162197View attachment 162198
The elliptical waveguide is to allow the c to c space to be as close as possible. If waveguides alone are considered in isolation, conical is more optimal.
Tangband
Sweden
Might be. But, the lateral and horisontal dispersion gonna be slightly different with an elliptical waveguide. Genelec uses this shape even in the big studio monitors they make . Is it only for making the c-to c closer ?
JBL also uses a different non-symmetrical shape in their waveguide for their professional speakers. I dont think its a coinsident.
Here is Genelecs paper on their waveguides. There is no information about making c-c shorter as a benefit.
Tangband
Sweden
Here is interesting reading about Revels waveguide, in this Harman paper:
Conventional waveguide theory states that broadband pattern control (i.e. directivity control) is best achieved by a large straight (conical) section in the waveguide, and that transition design at the entrance and exit of the waveguide are critical to prevent high frequency narrow-band directivity and frequency response problems. Finally, the size of the waveguide determines how low in frequency the waveguide can control pattern.
With previous generation waveguides, although the directivity was well matched at the crossover frequencies, they tended to have excess directivity and lower output above 9kHz.
A new generation slender wave guide along with an acoustic lens was developed for the Concerta2. The wave guide uses a large gentle blend radius at the exit of the waveguide. The directivity is now well matched to the midrange drivers of the Concerta2. The output is improved above 9kHz by adding an acoustic lens in front of the dome (Figure 7).”
bigjacko
I rememer that if waveguide is in perfect circle, the wave will be coherant and make on axis dip somewhere. The dip goes away at off axis so if the speaker is not pointed towards listener the on axis dip does not matter. Genelec sure does not want that, so not surprised if they don't use perfect circle.
Lbstyling
Yup. Pattern control at crossover is better when drivers are closer together (under 1/4 wavelength at cross is ideal). This problem doesn't go away when you make bigger speakers, it gets worse.
RE JBL, if your refering to the modern waveguides like the M2, they are symmetrical, yes.
If you mean they are not conical, well they sort of are actually. The odd shape with the narrowing corners in the throat is a mathematical calculation where you make the shape of a circle (the driver) match the shape of a square (the box) while keeping its Path length the same through the 360 degree radius of the horn. This is the closest you can go to replicate a conical pattern control with a rectangle mouth.
Move the material of the extra path length towards the throat, and you can also use it as a semi diffraction Device, fixing/helping the dispersion issue of the top octave with drivers of over 1" width exit.
tuga
Oxford, England
This paper is also worth a read, with interesting considerations regarding 3-way design:
The Acoustic Design of Minimum Diffraction Coaxial Loudspeakers with Integrated Waveguides
Aki Mäkivirta, Jussi Väisänen, Ilpo Martikainen, Thomas Lund, Siamäk Naghian
Genelec Oy, Iisalmi, Finland
ABSTRACT
Complementary to precision microphones, creating an ideal point source monitoring speaker has long been considered the holy grail of loudspeaker design. Coaxial transducers unfortunately typically come with several design compromises, such as adding intermodulation distortion, giving rise to various sources of diffraction, and resulting in somewhat restricted maximum output performance or frequency response. In this paper, we review the history of coaxial transducer design, considerations for an ideal point source loudspeaker, discuss the performance of a minimum diffraction coaxial loudspeaker and describe novel designs where the bottlenecks of conventional coaxial transducers have been eliminated. In these, the coaxial element also forms an integral part of a compact, continuous waveguide, thereby further facilitating smooth off-axis dispersion.
