display problem with DAC AUNE S6
fjordland
Ciao ragazzi,
Sono possessore di un DAC Aune S6 con un problema al display.
Appena collegato e acceso, il display non si accende. Dopo tre o quattro minuti il display si accende. Non l'ho mai notato prima.
È normale o c'è un problema?
Grazie in anticipo.
Marco
IAtaman
Ciao ragazzi,
Grazie in anticipo.
Marco
Hello and welcome :)
There is so much Latin in English, I can half understand what you are saying :)
And I think thanks in anticipation is a better phrase than thanks in advance - I am gonna use it.
Official language of the forum is English. I'd recommend DeepL for translation.
Hi guys,
I own an Aune S6 DAC with a problem with the display.
As soon as it is plugged in and turned on, the display does not turn on. After three or four minutes the display turns on. I have never noticed this before.
Is this normal or is there a problem?
Thank you in advance.
That sounds like a problem. If you can return it, I'd suggest you return and get a new one.
F
fjordland
Hi,
yes, it looks like a problem but I'm not sure.
The DAC is out of warranty.
I just wanted to know if it's normal that the display doesn't light up as soon as I plug it in.
The DAC works even with the display switched off.
Then slowly the display turns on.
I hope I have made myself clearer.
Thanks
Similar threads
