Dithering is a Mathematical Process - NOT a psychoacoustic process.
j_j
Audio Luminary
My kitchen or my listening room.
I have calculated a sine wave of magnitude .4, rounded it, added uniform dither, rounded that, and added tpd, and rounded THAT, i.e. I've set a step size of '1' in the quantizer.
The routine that does this will follow in a comment.
The photo I'm attaching now has 4 lines. each line shows a signal. The four columns are
(signal) (signal spectrum) (error signal) and (error spectrum)
The four lines are
undithered unquantized
undithered quantized - NOTE THE SIGNAL IS GONE. POOF, LOST, MISSING, GONE. Information is ***LOST***
uniform dithered quantized - Note, signal is back, but noise level changes with data value, so data modulates noise level.
TPD - Note, signal is back at same level, noise is 3dB higher, but there is no modulation of the noise level.
This shows, clearly, visibly, and without debate, that DITHERING PRESERVES INFORMATION.
That is all!
j_j
j_j
Audio Luminary
This script generates that screen shot:
clc
clear all
close all
x=.4*sin((1:8192)/512*2*pi);
xnd=round(x);
for ii=1:8192
t=rand();
xud(ii)=round(x(ii)+t-.5);
t=rand()+rand();
xtd(ii)=round(x(ii)+t-1);
end
xt=abs(fft(x));
xndt=abs(fft(xnd));
xudt=abs(fft(xud));
xtdt=abs(fft(xtd));
xe=x-x;
xnde=x-xnd;
xude=x-xud;
xtde=x-xtd;
xet=abs(fft(xe));
xndet=abs(fft(xnde));
xudet=abs(fft(xude));
xtdet=abs(fft(xtde));
subplot(4,4,1)
plot(x)
title('x');
subplot(4,4,2)
plot(xt);
title('spectrum of x');
subplot(4,4,3)
plot(xe)
title(' error');
subplot(4,4,4)
plot(xet)
title('error spectrum');
subplot(4,4,5)
plot(xnd);
title('no dither');
subplot(4,4,6)
plot(xndt);
title(' spectrum ');
subplot(4,4,7)
plot(xnde)
title('error');
subplot(4,4,8)
plot(xndet);
subplot(4,4,9)
plot(xud)
title('uniform dither')
subplot(4,4,10)
plot(xudt)
title('spectrum uniform');
subplot(4,4,11)
plot(xude)
title('error')
subplot(4,4,12)
plot(xudet)
subplot(4,4,13)
plot(xtd)
title('tpd');
subplot(4,4,14)
plot(xtdt)
title('tpd spectrum');
subplot(4,4,15)
plot(xtde)
title('tpd error');
subplot(4,4,16)
plot(xtdet)
title('tpd error spectrum');
j_j
j_j
Audio Luminary
I was going blind trying to read the plots then realized I could click on them for full size. :)
Thanks for the visualization. It helps a lot.
Yeah, there is a (*&(*&(*load of detail there. So I uploaded a full 1080P version. I might have done this at work and done a 4K, even, now that you point it out.
DonH56
Monument, CO
Nice job, @j_j ! Need to copy the script and fire up Matlab again.
I must have missed it -- who thought dither was psychoacoustic? How is such a conclusion even considered (I guess by audiophiles who dismiss all science and math as irrelevant?)
I first heard of dither (noise decorrelation) in the early 1980's and applied colored noise to an RF ADC for an X-band (8-12 GHz) radar system. It worked and I'm pretty sure no psychoacoustics were involved... :)
SIY
Alfred, NY
Sigh. This takes me back to my days at Nicolet...
/very old man
DonH56
Monument, CO
/very old man
Nicolet, that brings back some memories... What happened to NTI? Sure I knew at one time, senility.
SIY
Alfred, NY
A few years after I left, they were acquired by Thermo-Fisher. AFAIK, the digital scopes are long gone, but their analytical instrumentation is still around, though with NIC sort of in the background as a brand.
pkane
North-East
The four lines areView attachment 47956
That is all!
Here's an example of 4 bit quantization of 1kHz signal using my DISTORT software.
No dither:
TPDF dither:
Shaped dither, pushing quantization noise to higher frequencies (unfiltered):
Shaped dither, filtered at 20kHz:
Matias
São Paulo, Brazil
solderdude
The Neitherlands
As far as I know, there are different dithering algorithms that generate different noise shaping responses, and the developers choose them by psychoacoustics tests.
The demo by @j_j was intended to show what dither does (preventing truncation) showing adding dither is and not :
Dithering is a signal processing that always results in degradation of a signal waveform (adding noise) but the same time it improves auditory perception of that signal..... So, dithering is a perfect example of psychoacoustic treatment of audio signal
Of course the NS3™ algorithm is based on psychoacoustic tests and improves the final result of added jitter by shifting noise into higher frequencies that are less audible by changing the 'shape' of the jitter as shown by @pkane. Paul's shaped dither most likely differs a bit from NS3™.
pkane
North-East
DISTORT shaped dither is my own creation and will bear no resemblance to anything else out there. It was just meant to help demonstrate the difference between no dither, TPDF, and a simple shaped dither :) Of course, this being part of DISTORT, you can also listen to the differences.
Hayabusa
Abu Dhabi
The dither can be noise shaped with psycho-acoustic rules to minimize the audibility.
DonH56
Monument, CO
spin off from here
Ah, thank you. Using psychoacoustics (is that a euphemism for listening tests in this context?) to decide what sort of dither to use seems fundamentally different than explaining how dither works.
In my example the applied noise was out of the signal band and still impacted in-band signals as desired. It did require higher amplitude, natch. I do not recall trying different envelope shapes at that time; white noise is the only source I had and I filtered it to obtain the desired passband. It was a flash ADC, not delta-sigma.
DonH56
Monument, CO
What rules? Curious... My system shaped the noise to move it out of band and control the amplitude. What sort of psychoacoustic rules are used to optimize dither in audio systems? Do they correlate to the math? Noise decorrelation is pretty well defined and has been for decades; I don't know anything (relatively) about psychoacoustics.
Veri
I suppose Radsone's marketing of their "advanced dithering" is just BS?
They're quite literally advertising two "Radsone-tuned" dithering modes.
DonH56
Monument, CO
There are a myriad of ways to apply noise decorrelation but fundamentally they should all do the same basic things as shown by @j_j. Level (amplitude) and "shaping" of the applied noise will certainly produce measurable, and probably audible, differences in the noise floor and such. Guess I am still confused on the debate. You can use psychoacoustics to tweak whatever you want, but dither itself is a known process and predictable (statistically) results. As an analogy, if I add distortion (dither), the effects are measurable and predictable; psychoacoustics should predict whether I like it or not. I think; psychoacoustics is way out of my field.
