DIY Purifi Amp builds
starfly
It is not normal to use this with an SMPS1200A400. It is certainly NOT necessary.
Ok, thanks. I'll probably just skip that then. What are the main specs I should look for in a power supply that will provide standby power, and allow use with a 12V trigger? I think @JimM had used a MeanWell IRM-30 power supply. Can I just get anything that's similar to that? I'd prefer a more open design than that MeanWell power supply, as I suspect it might run a bit cooler that way.
And if I want to have two 12V trigger inputs, can I just splice the wires for each together and have them both enter the same power supply?
Also for the IEC socket that connects to the mains, what fuse rating is recommended?
Matias
São Paulo, Brazil
I sent an e-mail to Modushop asking if they would customize the back plate for the necessary holes of the EVAL1 kit, and sent them the link to this thread.
Would the EVAL1 kit + Purifi amp modules + SMPS1200A400 + IEC with on/off switch fit into this case below?
Galaxy Maggiorato GX288 230 x 280 mm 10mm front panel BLACK
Width: body 230mm, inner useful 210mm
Height: 80mm
Depth: 280mm
Weight: 2,0 KG
49.50€
https://modushop.biz/site/index.php?route=product/product&path=25_291_293&product_id=444
phoenixdogfan
Nashville
Height: 80mm
Depth: 280mm
Weight: 2,0 KG
49.50€
The depth looks too shallow to me. My Ghent case is 315 mm deep and it's a tight fit. May and be if you're going to drill your own holes in the back and bring the edge of the Eval 1 so it's flush with the back panel it might work, but even so I think it would be tight if it fits at all.
J
JimB
California
ABSOLUTE MINIMUM inside depth to fit an EVAL1 and an SMPS1200A400 is 250 mm.
Matias
São Paulo, Brazil
TimoJ
Finland
Thanks a lot for the confirmation. My build would be very similar to yours, but I would keep the banana connectors and use a IEC connector with fuse holder and on/off switch. Should be basic and easy as possible for a first time DIYer like me. :)
Yes, should be pretty easy job once you get all the holes drilled and lined up. Are you going to take the fully slotted/ventilated top cover option? I only have the regular one and have installed panels so that the ventilation slots on the bottom are near the back and on the top are near the front i.e. just over the PSU.
I'm going to soon order their GX388 model for a multichannel amp I'm building with Icepower 50ASX2 modules.
Matias
São Paulo, Brazil
I am not 100% sure I will move forward with this project. But if I were, I would use the regular top cover. IMO the whole heating thing is way overrated as this module is highly efficient. I am not going to test it running flat out on resistors for hours or something. Real world music listening, even long time on high volume, was shown that it barely gets warm (as per barrows post).
starfly
Looking at the SMPS3KA400 power supply from Hypex, it mentions the following:
The SMPS3K is intended to power our range of high power amplifier modules. As a result, this SMPS product
does not feature the 2-quadrant operation as most of our other SMPS products do. Therefore, they are unable
to handle large reverse currents generated by half-bridge amplifiers operated at low frequencies. For this
reason, it is not advisable to use this SMPS to power half bridge amplifiers like our UcD700 and UcD400
modules when used in the frequency range below 100Hz. A workaround for this could be using the
UcD700/UcD400 in bridge mode, or reversing phase for half of the modules
Anyone know what they mean exactly, reversing phase for half of the modules? I'm considering use this power supply for a 3ch amplifier, and well, half of the modules would be 1.5 modules. And then, what exactly do they mean by reversing phase? How would that be done on the Purifi module?
3ll3d00d
Swap the wires on both the input from the XLR and the output to the speakers so the resulting output retains the same polarity.
Hypex engineering comment that best results mean using an even number of modules but find it hard to say the extent to which supply pumping will be an issue. This is probably because, as I understand it, the extent to which reversing phase helps will depend on the extent to which the channels are amplifying correlated content. The only way to find out will be to try it but I don't believe they will cover failures in this scenario under warranty so it is a bit of a risky one.
TimoJ
Finland
What about if you just put two power supplies SMPS1200A400 for L/R and SMPS600A400 for the center?
SIY
Alfred, NY
my ear confirms sinad that's all, i just suggest that he try to compare ... it costs nothing, just switches to move
If you don't level-match to better than 0.1dB and compare blind, your "ear" is not what's in play.
PaulD
Other
I know ... i know your point of view...
But it don’t cost anything to try it .... and Sinad agrees with my ears
Yes it does cost something, it denies science and misleads people with potentially very false information. You can play those games with yourself, but presenting it as some sort of "result" when we all know it is not is just publishing BS... Far more likely is that you "hear" what your mind tells you the SINAD should "sound" like...
You are far better off not reporting it, or even better is participating and supporting a study that WILL give something worthwhile, like a level matched DB test.
Wombat
Australia
@Dbfr you are out of your depth, mate. Not uncommon on ASR, nowadays.
Dbfr
keep in mind that what makes you're looking for the best is to give pleasure to your ears ...
I just suggest to someone who is not using the full potential of his DAC to do this test and so don't use the buffer stage and give us his feelings.
Yes it will a feeling and not a measured fact, but what makes us vibrate are our ears. The microphone and the oscilloscope are facts, but the ear is the judge of the final result, those that say whether one takes pleasure in listening or not.
It will remain a "feeling" I agree ...
i think i'm going to delete all my post and photos...
Wombat
Australia
No need to do that.
starfly
Thanks. Not sure I want to take that risk. Purifi themselves told me that the smps1200 will likely be adequate for a 3ch setup, and if it lacks power it's better to add a smps600 or another smps1200.
They say 3 channels will be hard to balance with the smps3k, and perhaps the only way to do it well is to use the 3rd channel in btl (bridged, right?) mode. But that would mean getting two modules for 1 channel, which is overkill to me.
So I think I'll just stick to the smps1200 at this point, and when I add a 3rd channel just splice all the wiring, or get the smps600.
Vincentponcet
They talk about UcD700/UcD400.
I read somewhere that Purifi amp is not subject to power supply pumping because the way they use power supply.
