DIY Purifi Amp builds
grobalt
OK, Purifi gave me a few more details regarding this mono input buffer, and I'll just copy and paste it here from the email they sent me. Pretty sure they won't mind, as if this were confidential they likely wouldn't have shared it with me. It's free marketing for them :)
  • 14dB SE/Ballanced gain stage based on OPA1612 with Panasonic thin film 0.1% resistors and Kemet NP0 linear capacitors.
    total system gain is 27dB as for the EVAL1 kit
  • Gain stage can be bypassed
  • Very low noise and low output impedance linear regulators for the gain stage and for analog circuits on the 1ET400 module
  • Available with XLR/Speakon connectors or without
Prices aren't final yet and they hope to have it on the webshop by early June. Their current thinking is a price of 150USD for the fully stuffed version and around 135USD without XLR/Speakon connectors.
The board is manufactured and tested in DK
Any News on this ?
Luc
But the Nord is more than 350 Euro per Channel, thus isnt cheap as well, right ? This ist the Same price than the amp channel
Yes, you're right. Very expensive and that's why i did not do that from the beginning. although i really would like to be able to switch opamp and voltage regulators easily
March Audio
Albany Western Australia
SMPS in STANDBY mode power consumption is 1.9W
SMPS in RUN mode power consumption is 10.7W Amplifier not connected
Hope that answers your question.
Thanks
Im no expert on the regulations, but doesnt the EU now mandate that standby power must be below 0.5 watts?
Might not be relevant for DIY products
somebodyelse
kukocz
PL
I have four boards - none are populated there.
Interesting...
Are you using J3.2 READY signal in any of your boards? I’m curious what voltage level you have there.
J
JimB
California
Interesting...
I'm not using that and am not able to check it right now. Hopefully someone else can test that for you to compare. It should be 3.3V logic.
grobalt
Maybe someone can help me with some feedback. Thinking about 3 Stereo Purifi amps, but in one case. Looking at Apollon Audio they use 3x Hypex 1200 for 3 Channel ! Looks a bit weird with an amp rated 450W, right ?
My idea was one microaudio with 700w or 1000w for Stereo but in comparison this is way less than what Apollon uses.
MicroAudio
AMMAN - JORDAN
SMPS1K-PFC can easily deliver up to 20A with a 10V drop only!
Voltage in idle 127VDC, SMPS loaded 16A voltage measured 118VDC
That's 1900W from a 1KW SMPS.
Hope that helps
starfly
Question about wiring up an AC/DC converter. I'll be using the Meanwell LRS-35-12 converter, and it has the following block-diagram:
And the converter looks like this:
So I wire up Live and Neutral A/C, and send DC 12V to the SMPS for standby circuit, etc.
This converter also has a ground terminal. I was planning on attaching this wire at the same spot I have grounded my IEC A/C socket (on the chassis rear-panel; I confirmed with an ohm meter that any other grounding points in the chassis flow to that point). Is that the correct way to do it?
J
JimB
California
... This converter also has a ground terminal. I was planning on attaching this wire at the same spot I have grounded my IEC A/C socket (on the chassis rear-panel; I confirmed with an ohm meter that any other grounding points in the chassis flow to that point). Is that the correct way to do it?
Your 'converter' is a mains power supply. You should ground it as you say. Did you consider a lower power unit, without ground?
starfly
Thanks. I actually hadn't, I suspected this one would run a bit cooler than those smaller units fully encased in plastic. But maybe I'm wrong.
I'll make sure to ground it to the same spot I have my IEC socket grounded.
starfly
Anyone know if this thing on an XLR also needs to be wired up to something?
D
Deleted member 65
Guest
Guess it’s the pin 1 to chassies.
Edit: If you measure the pin it’ll be connected to metal body of XLR, so short wire from pin 1 to this and you’re set.
Edit 2: Seems you’ve already connected pin 1 to chassies so ignore my comment.
