DIY Purifi Amp builds
TimoJ
Finland
I wondering if I use just one SMPS1200A400 and wire EVAL1 and one EVAL2 to it i.e. 3 channel amp, would there be problems? Or should I forget that and use SMPS600N400 (or SMPS400A400) for the EVAL2?
J
JimB
California
Personally, I would consider your first suggestion, if cosmetics of the back panel won't offend you. It would certainly cost less than three EVAL2s and performance would be the same. Adding an SMPS600N400 for the EVAL2 would support maximum output, into low impedance loads, from all channels, simultaneously. A single SMPS1200A400 for three channels will not do that, but it would be adequate for my needs (higher impedances and lower volumes), while still having good peak power.
TimoJ
Finland
I already have build a Purifi amp with EVAL1, so I would need just one EVAL2 and a new case. I'm using low volume with sensitive speakers, so losing some maximum simultaneous output won't be a problem. I could also position the SMPS1200A400 so that there is still space to install SMPS600N400 later.
KarVi71
Very nice! Are you driving it with the XLR output of the NAD C658 to the EVAL2/1ET400 combination with the buffer bypassed or not bypassed?
I'm running XLR to the Eval 2's and the buffer is not by-passed.
Havent tried the by-pass setting, and am not planing to.
I suspect the output voltage of the C658 would be insufficient (for max output) ...?
J
JimB
California
This is the only temp measurement I’ve seen on the Purifi. 50C idle, top open in a Nord case.
Of course, those hot component are air cooled and their temps will rise significantly with the top on. Any data on temps in your (super cooled) build?
D
Deleted member 65
Guest
No temp measuremen here, I have no equipment to do temp measurements. Would be interesting to see temps when amp is under load.
Looking at purifi’s doc temp can be retrieved, see 5.4 I2C Register map, Reg 0x11 Temperature.
Edit: Seems only available in SW mode.
J
JimB
California
I worked with Ghent on the venting of their new case. I'll try to get a thermocouple measurement, with cover on, at moderate power, once I get and build mine.
drfous
Valley of the Sun
Hiss out of the right channel.
So I got the kit together using the Ghent case and wiring harness. I have a strong hiss out of the right channel only with and without inputs connected. I've shielded all the cable running between boards and the mains line with copper tape. No effect.
I'm using the jumper for 120v usage.
No change to the gain jumpers. Using stock.
Any input would be appreciated.
Thx
J
JimB
California
Thx
Hypex SMPS1200A400 used? Reaching for easy possibilities, are your jumpers J6 and J7 set to VAUX, not the default of VAUX,REG?
7.6 Jumper Setting (VAUX or VAUX,REG)
J6 and J7 are used to select the output voltage on pin J4.1 and J4.2.
• Position 1-2: Regulated VAUX,REG
• Position 2-3: Unregulated VAUX
When the connected amplifier is fitted with HxR voltage regulators, both jumpers need to be set to
unregulated Auxiliary voltages. VAUX,REG is the default jumper setting (J6, J7).
drfous
Valley of the Sun
Music, sweet music.
Thanks, Jim!!! It was the regulated/unregulated jumpers. I didn't pick that up reading through the materials.
We are in business.
J
JimB
California
Music, sweet music.
We are in business.
Great. Of course, one could wonder why it was good for one channel but not the other - just differences in parts being operated out of spec.
yardbird
I have the Purifi case and harness from Ghent, the eval 1 and the hypex 1200-400. The PS powers fine when not connected. When the power and Aux cable are connected, no LED on the PS and no power to the amp board. i did not wire the SpeakOns. Looking a the Aux cable, it appears to be wired backwards. Sent a note to Ghent to confim. Is anyone here able to confirm?
thanks,
Jeff
