SuicideSquid
- Joined
- Jan 20, 2022
- Messages
- 702
- Likes
- 1,658
Hi Folks,
I'd very much appreciate your feedback on the following project.
My main system features a pair of Totem Forest speakers in cherry. I've had them for around fourteen years and I love them and have no intention of replacing them any time in the near future.
I've been using them in stereo for years, but am moving and have the opportunity to integrate them into a surround sound setup. Totem doesn't really make a matching centre channel - the closest is the Model One Centre, but two issues: I don't particularly like either the aesthetics or the sound of the standard "MTM-on-its-side" centre channel, and Totem no longer makes this speaker in cherry. They do make a bookshelf version of the Forest, called the Signature One, but again, they no longer make these in cherry - black, white, or mahogany only.
I have some experience building speakers, so my new DIY project is to duplicate the Signature One speaker, in a cherry cabinet. I've got the Hivi D6.8 woofer and SEAS tweeter, and this weekend I glued up some cherry and MDF and started prepping the cabinet.
Where I'm stumbling is the crossover. I know that Totem uses a 2.5kHz 2nd-order crossover in both the Forest and Signature One, though I'm not sure if the Signature One uses the identical crossover to the Forest. I have X-over Pro CAD software and can design something that'd likely function well and be pretty similar.
But then I started thinking, "Why don't I just use an active crossover instead of messing around trying to copy a passive crossover?"
My current setup is a Denon 4700H AV Receiver outputting to a six-channel hypex Buckeye amplifier - I'm currently bi-amping the Forests. So I have two more channels of amplifier I can use for the centre channel (and then use the Denon's internal amps for rear / overhead speakers).
I feel like I may just be swapping one problem for another though. And I'm not sure whether I should be looking at something like the dbx223 analog active crossover, or something like a miniDSP digital active crossover. The room sounds good and will have room treatment so I'm all right sticking with the Audyssey EQ/correction built into the Denon rather than setting up dirac. Mostly I'm concerned with ease of use and transparency, as my family will all be using the system and I don't want someone (including me) to be easily able to screw up the crossover settings and potentially damage the speaker.
And assuming it works well with the centre channel, I may pull the crossovers out of the Forests and switch them to active as well.
Long way of getting to the point but:
Should I build a passive crossover, or take this opportunity to go active? If I go active, digital or analog? Your feedback much appreciated!
