DIY: Summer Projects
Silou
Silou
So 24V is present on pin4 and pin8 of U2 but there is no voltage present on C8 and C9 ?
No there is no voltage on Pin 8 and Pin 2 of U2 and no voltage present on C8 and C9
The LED was not on aswell
solderdude
The Neitherlands
no voltage on pin4 and pin8 of U2
When that is the case the power switch is not connected correctly or not jumpered correctly.
2 & 3 of S1 and 5 & 6 of S1 must be connected.
Silou
Silou
I meant pin 4 and pin 8. I did not jumper the power switch. Will do and report back in a few minutes
Silou
Silou
11.95V and 11.96V on C8 and C9 now
LED is on aswell
"U2 must be installed as well as the power switch. " I did overread that :facepalm:
solderdude
The Neitherlands
Time to install U1, U3, U4 and the volume control
solderdude
The Neitherlands
measure the DC voltage on the output of each U1, U3 and U4 opamp, so pin 1 to ground and pin 7 to ground.
They all should measure (close to 0V).
When that is a pass you can connect some music or test tone to the input signal and see (scope) or listen (with a cheap headphone) to the output signal (SE) and listen if it works as expected.
For this test you don't need the gain switch yet.
Silou
Silou
U3 & U4 Pin 1 & 7 = 5mV
U1 Pin 1 & 7 = -1,4mV
It works :D:cool:
solderdude
The Neitherlands
congrats...
Next stop .... getting the negative amp working.
Silou
Silou
All the parts from the modified schematic are soldered on.
solderdude
The Neitherlands
Next step is to follow instructions in post #113
Once that is done repeat for the negative board:
When that is a pass you can connect some music to the fully assembled (+ board) or test tone to the input signal and see (scope) or listen (with a cheap headphone) to the output signal (SE) of the Negative board and listen if it works as expected.
For this test you also don't need the gain switch yet.
Once this is O.K. as well, You can connect the balanced headphone. If you don't have balanced cables yet I will tell a trick how to test the amp (channel by channel) using TRS headphone.
Silou
Silou
U3 and U4 are fine with 5mV, but U1 is 10V and -10V :eek:
solderdude
The Neitherlands
Did you make the connection between:
pin 1 (Left side R17) from the - board will be connected to pin 1 of U4A (left side R18) of the + side board.
pin 4 (Left side R21) from the - board will be connected to pin 1 of U3A (left side R11) of the + side board.
Silou
Silou
You probably meant the left side of the pins in the schematic. I think i double checked it, but that could be the problem.
solderdude
The Neitherlands
These wires need to go from the '+ board' to the '- board' not being run on the same board.
+ board being the fully populated one (which is a standard O2) and the - board being the half empty board which has an inverter and buffers only.
So...
pin 1 (Left side R17) from the - board must be connected to pin 1 of U4A (left side R18) of the + side board.
pin 4 (Left side R21) from the - board must be connected to pin 1 of U3A (left side R11) of the + side board.
What these wires do is take the positive signals (So R+ and L+) and connect that to the inputs of the - board.
U1 is configured as a -1 gain amplifier (so an inverter).
That inverted signal goes to the output IC's on the - board.
Silou
Silou
Maybe the picture is not a good way to illustraste the wiring. The + on the picture shows the +board and the - shows the -board. I did not run them on the same board. Just wanted to make sure the wiring is correct and the correct pins are connected.
solderdude
The Neitherlands
On the negative board the wires need to be connected to the other side of R17 and the other side R21 !
So the holes of those resistors being closest to the edge of the board.
Silou
Silou
I will change the wiring of R17 and R21 tomorrow and measure U1 again.
I modded my DT770 and K712 in the last days so they can be used balanced. I would like to test with some cheap headphones first. What is the trick you mentioned earlier?
Is that the correct wiring?
P2 positive board:
pin1: L+
pin2: R+
P2 negative board:
pin3: L-
pin4: R-
solderdude
The Neitherlands
The trick for testing using a cheap headphone with TRS:
R+ to Tip and R- to shield (you will only hear the R channel one the right earpiece)
when that channel works to test the L channel do the same but with L+ to Tip and L- to shield (you will only hear the L channel one the right earpiece)
You can not and must not test L and R at the same time...
When that works you can connect a 4-pin XLR:
R+ = 4 (P2Off Board Output) positive board -> (insert filters here later) -> pin-3 XLR
L+ = 3 (P2Off Board Output) positive board -> (insert filters here later) -> pin-1 XLR
R- = 4 (P2Off Board Output) negative board -> pin-4 XLR
L- = 3 (P2Off Board Output) negative board -> pin-2 XLR
The TRS on the amp will be connected like this:
pin-3 XLR to Ring
pin-1 XLR to Tip
pin 2 from P2Off Board Output positive board (so NOT from the XLR) to Sleeve
solderdude
The Neitherlands
For the filter indication LED do you want to use 4 LEDs (same colour, different colour) that indicates the position or want to use a single 3-color LED and make colours like red, green, blue and purple (or yellow) ?
