Do I need a "surge protector" ?
tamtam
Hey folks,
I'm trying to understand the type of protection my gear needs, if at all.
A lot of discussions about power conditioner, but I'm not trying to improve the sound.
We have a pretty stable electricity supply - 220v, but having short blackouts, mostly during storms. Approximately 5 times a year.
If I understand correctly, after a blackout there will be a spike when power goes up.
So I'm looking to buy a surge protector, one of the best I can find in the area I live.
Specs say <180Vac and >270Vac range, when not in a range it will disconnect. Can absorb 1000J. Rohs/CE/CB certification.
It also protects from over and under voltage.
Is it on a level of snake oil or it actually helps?
I'm also aware this device if not properly made it can "burn" the downstream electronics, that's why I'm looking at certifications.
I have purchased some "high-end" audio gear recently and want to keep it safe.
Thanks
T
tamtam
Thanks, so I understand they do offer an additional protection and increase the life of electronics.
I found this device, probably the best I can find where I live. Is it any good?
I saw some people mention these devices make sound worse? Sounds like a placebo effect, right?
Trying to get some reliable opinions without doing a PhD in electronics...
solderdude
The Neitherlands
Surge protectors can only clamp very short peaks (transients) and not longer over voltages. Usually they clamp well over the nominal mains voltage.
They will not do much against lightning strikes (near-by).
I would recommend stuff like this installed in the breaker box when you are plagued by lightning strikes reasonably near-by:
It won't protect for longer term overvoltage though.
DVDdoug
Not necessarily. Almost any kind of fault is possible.
My power in California is more reliable than yours but I've never had anything damaged by a power surge.
I've never heard of one that disconnects with low power but possibly it does.
it can, but it won't protect against everything. A direct lightening strike to a nearby power line (or anything extreme) can probably still do damage.
That won't happen. But if the device itself is badly made it could burn-up or shock you.
If you have electrical noise on the power line that's causing noise in your speakers/headphones it might help. But it won't filter-out everything and your audio equipment already has built-in filters.
Actually, they can. They work by "shorting" when there is excess voltage and there's usually a built-in fuse or circuit breaker that blows to cut-off power if the over-voltage lasts long enough.
T
tamtam
It's called Under voltage protection and Over voltage protection.
Usually it comes with a delay of 3-5 minutes, when the threshold is passed.
I saw someone tested this kind of device, and the the lower threshold the UVP stuck in an indefinite on/off loop potentially causing more damage to the electronics than helping. Also, I don't see many devices have this feature.
The second device, Tripp Lite Isobar has a
  • Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required
and
  • An integrated 9A circuit breaker protects all outlets and shuts down connected equipment in the event of an overload.
However, not sure if this is the same Over voltage protection as in the first device.
egellings
I worked for a company that makes a variety of surge protection devices among other things, and the first line of defense against lightning surges was a carbon block spark gap device that could clamp the let-through voltage to under 1kV. after that, secondary surge devices such as GDTs (Gas Discharge Tubes), active surge suppressors and MOVs, could be deployed to clean up the rest of the surge energy. However, a really large direct hit could just blow everything up.
solderdude
The Neitherlands
Yep, a direct hit (or very close by) will destroy just about anything.
The OP seems more worried about brown/black-outs where on 'start-up' the mains voltage is temporarily too high.
This is possible when the OP is closer to the mains generator than most of the other users which will all 'dip' the generator on power-up with all their inrush currents.
Here these nor any TVS/MOVs/gastubes can be of any value.
In such case an UPS with over/under voltage protection might be fast enough or the usage of a regenerative UPS might be a good option.
When it is to protect high$ audio gear this might be an option.
Barrelhouse Solly
At worst they're harmless. The last test of surge protectors I've seen was in the '90s. At that time nothing on the market could protect against a lightning strike. I've had a couple of them since the late '80s. Neither has ever tripped. Today's gear may be substantially better. I don't know.
T
tamtam
Thanks everyone, got the Tripp lite isobar with filtering.
I don't know if this is placebo, but sound became slightly better.
rdenney
I've lost electronic equipment due to surges caused by power interruptions. That includes things like control boards in appliances and the like. I've never lost anything that was plugged into a decent surge suppressor (and Tripp-lite is reputable) or a UPS with (additionally) surge-protected outlets. What I have lost was not so protected.
In my new shop, where I did all the electrical work, I installed panel surge-suppression devices. What makes them work well is the low-impedance path to a good earth ground, one that is kept very short (in my case, five feet). In that building, it's a Ufer ground that provides a ring of equal potential around the perimeter of the building.
Rick "preferring the panel manufacturer's panel-mounted surge protector to any downstream alternative, but only if the panel's ground is close and of good quality" Denney
T
tamtam
Unfortunately, what I thought as a better sound actually just a saturation from filter banks. On the bank with the "better" filtering - more saturation.
Sound from the main socket sounds cleaner and more detailed. :facepalm:
However, it's easier now to hear dynamics.
Having a mixed feeling about this now.
