Do USB Audio Cables Make A Difference?
KSTR
Berlin, Germany
I'm under the impression that most modern DACs use asynchronous mode, where the clock master is local in the DAC and a feedback mechanism to the host is used (together with buffering) to control the host's timing for the USB packets.
As described eg here : https://thewelltemperedcomputer.com/KB/USB.html
Eirikur
Yes, but clock≠data-transport; all packets are still sent using isochronous transfer as per USB audio protocol.
Proprietary modes could be implemented, making the DAC dependent on OS specific software drivers to function.
solderdude
The Neitherlands
AFAIK:
All DACs use Isochronous Datatransfer.
Within Isochronous data transfer there are 3 possible modes for syncing.
Synchronous mode: This is where the data speed is controlled by the PC
Asynchronous mode: This is where the data speed is controlled by the DAC
Adaptive mode: This is where the data speed is controlled by the clock of the PC
The synchronous and adaptive modes are not preferred as PC's do not have the most stable clocks.
For a cable this doesn't make a difference.
mansr
Hampshire
The DAC endpoint is asynchronous. The host endpoint is adaptive using feedback from DAC.
MOCKBA
Why USB cable makes a difference? it is because no error corrections for audio usage?
mkawa
Which troll are you referring to?
the OP seems like a series of measurements presented to give cable adherents a false hope as well as dump on a poorly designed schiit product.
what i didn't realized is that someone necro'd this thread from years ago.
PaulD
Other
Radiated and transmitted noise probably, but it's not any audible difference - see post 1.
solderdude
The Neitherlands
The test was done using a DAC with a poorer USB implementation.
In fact the Schiit DACs were known for this and is why Schiit has other products to improve on that.
So the 'cable makes a substantial measurable difference' which may not have to be audible at all only applies to some DACs.
As mentioned by the OP this seems caused by the length of the USB cable.
One thing that is of importance is that this DAC is fed from the USB. This means that the power supply current to the DAC passes through the USB cable.
This is the most important factor in this case.
Long (generic) cables most likely have thin wires inside. This means there are losses that are not audio related but drawn power from digital (switching) circuits related.
So there will be some 'spikes' between ground (0V) and the 5V power supply.
This should not be a problem when input filtering of the power supply is sufficient.
This is theoretically very nice BUT there is also something like PCB design. The way wire (traces) run over a PCB that has BOTH digital signals AND analog signals.
Make a small groundplane or layout or groundplanes coupling error and some of the digital 'nasties' can actually go into the audible path.
This is even more true when there is also a groundloop with the amplifiers connected to the DAC.
Not saying this IS the reason, merely it could be one of the reasons.
So in this case the most likely scenario is that due to resistive losses in the USB cable a very small percentage of the current drawn from the digital circuits may have found its way in the analog path which is what is measured.
As can be seen we are talking -126dB peaks (relative to 2V) so we are in 1 microVolt territory with the long cable for audio or the digital receiver used is misinterpreting 'decision levels' and the rest of the DAC is more sensitive to the jitter this causes (poor jitter rejection).
Another issue could be (since this was shown in a jitter test) that the used USB receiver was not well implemented/designed.
Not so strange as Schiit just recently 'admitted' they finally fixed USB. One could read this as 'we finally made a good USB receiver and all that became before it was a bit flawed.
So the other likely scenario in this case is there was a higher than desirable amount of 'digital garbage' on the data/and or power supply lines (resistive and maybe even capacitive/impedance matching issues) that the used USB receiver had problems correctly deciphering the digital waveform it did receive and something in that circuit made jitter worse which wasn't properly reduced in the DAC itself.
So... we don't know for sure WHAT exactly caused this as it wasn't investigated.
The only thing that we can conclude is that in case of the Schiit modi2 DAC the length of a generic cable resulted in slightly higher measurement errors that may well have remained inaudible (skirting hasn't widened).
That is, when no digital volume control has been used at say -40dB or so.
This too we don't know as it has not been tested.
In short... it is unknown what caused the difference in measurements but seems related to a specific DAC and cable length (cable resistance/bandwidth related ?). It can be caused by a number of reasons.
It was also shown that another DAC was not 'affected' at all.
scott wurcer
Audio Luminary
That's interesting I've never come across a USB based audio interface (E-MU, Focusrite, MAudio, etc.) that failed a loopback due to a cable. This would be data to DAC and data from A to D simultaneously over USB.
solderdude
The Neitherlands
Would you consider the test Amir did a loopback test? The Modi does not have its own ADC.
If so then would one consider connecting the USB input and Analog output to another device a loopback as well ?
I never had a loopback test give poorer or better results as well regardless if there were USB improvements in the chain but only tested very few DAC/ADC's that way (E-MU, Behringer)
DonH56
Monument, CO
A friend and I have tested Focusrite, mAudio, and another brand I've forgotten (no E-Mu or Behringer, maybe Alesis? years ago) and again no problems/changes. Sounds like the only problem is with Schitt?
I have had ground/power issues on several devices but cannot say what the problem was. A different USB did not always fix it so sometimes it is an isolation problem of the unit itself and not the cable. As Amir's testing has clearly shown.
scott wurcer
Audio Luminary
Done that too, just trying to say I never had a USB cable corrupt data.
solderdude
The Neitherlands
In my reply I said nothing about corrupted data.
I spoke about poor jitter rejection and 'leakage' from digital circuits in the analog circuits due to poor layout, resistive losses in long USB cables and also about effects of ground-loops.
1uV relative to 2V I would hardly call audible but is measurable and might explain what was seen in the mentioned DAC but was not seen in other DACs.
DonH56
Monument, CO
The only times a USB cable has corrupted the data IME was when the cable was bad, either a broken shield or broken wire so it was single-ended.
dbfreak
I settled on a 10” DIY Moon Audio Blue Dragon cable for my USB DAC needs. She’s music to my ears.
Julf
Amsterdam, The Netherlands
Even more music to the wallet of your dealer.
